QUOTE (Rusty Baker @ Sep 9 2009, 12:19 AM)
Craig, I'm not sure if this is what you are looking for but this is the setup I use at night and when traveling so the door doesn't fly open. I leave the window in the door unlocked so that I can slide it open, reach in and unlock the slide. To install,I took the door handle off then glued a wood block on the inside so the slide could be attached to something sturdy. I attached another wood block, as you see in the picture, for the slide to rest on . When closed it's tighter than a tick and won't come undone without help.http://www.fiberglassrv.com/board/style_images/1/folder_attach_images/attach_add.png
Thanks, Rusty. That looks like it worked out pretty well and does the job, but I'd like to be able to open it with a key if possible. I was looking at the door and it seems to be about the same thickness as a typical home entry door. I think I will do some measuring and see if I can somehow get a deadbolt to mount and look good.
