QUOTE (D Tharp @ Sep 12 2009, 04:37 AM)
Ok after installing my new LEDS and
Getting a battery monitor.
I now know that my POWER CONVERTER is not poviding power to the battery.
Installed an ELIXER converter in 2005 went bad in 2007 they replaced it, now 2009 went bad again.
So I am wondering what everyone is using out there.
I do travel backcountry road so need something that will work well and last.
I boondock so most power comes from SOLAR Panels but like to plug in sometimes on the road and at home to chill down the fridge and keep the battery up.
So any info would help alot. Do not need a large one 20 AMPS will be fine.
THANKS DAVE
This is a tough question... Scamp used American for years with most people getting good service from them, But I know of several people who have had them fail repeatedly.
Mine is flawless after 6 seasons, but it would be tough to recommend any particular brand since failure rates depend on load, care and luck and are not very well documented.
Here are a couple of hints for long converter life though...
1] Evict the dust bunnies every couple of years!
2] Be sure that the converter is mounted in a well ventilated area.
Some sixteens have them under the side dinette with no vent. if yours is
there, simply add a vent under the seat.
3] kept the area behind the converter free from stored items that could block
ventilation and cause overheating
4] Check for fan operation regularly ..... even better and maybe overkill, add power ventilation to the compartment ( it can be 110V if you choose since the converter only works on shore power!)
As you can see , my point is that HEAT is a converter's worst enemy!
