QUOTE (Bryan L. @ Sep 27 2009, 09:51 PM)
Just press the up arrow until it gets to 6.0 to start with and you drive it and test it and then keep adjusting it from that point based on your results. The voltage reading is what you are adjusting. At rest, it will always be zero and you are adjusting for the "maximum" voltage that is necessary to stop your trailer. When you put the manual lever all the way to the left, it will give you your maximum voltage that is being applied. Hope that helps.
What I mean is that I never get to adjust the numbers as yo suggest.All I see when I adjust the power buttons is a Voltage reading,it never shows anything else while adjusting?
I certainly read exactly what you suggest in the manual but again mine only displays the voltage when I press the buttons.
Do I just misunderstand what I am reading?
Am I supposed to see the Voltage only while adjusting and then only see the other numbers while actualy applying the brakes?
Also it does seem to work and I am certainly getting trailer brake action from it,I just can not understand the adjustment without seeing anything but the Voltage?
Ed
