QUOTE (sean m @ Sep 30 2009, 07:09 PM)
hi guys, i'm new here, and i just bought a 1995 16ft scamp that i haven't seen yet. i know that's crazy, but it was $2k and the pictures were plentiful. hopefully any work it might need will be within it's value.
questions..
#1. it looks to have a wood interior, does that weigh more than than the standard?
#2. what is a good brake controller to install in my van(i'm assuming the 16ft would have brakes)?
#3. is that a 2" ball?
#4. what things do i need to check out before i tow it 6 hours home?
i hope that's not too much for one post.
thanks!
sean
1] Weight difference atributable to cabinet material is negligible,However, the deluxe tends to have more options and more cabinets which of course add weight.
2]Prodigy
3] YES
4] be sure your TV has an RV plug that works and check the lights.
inspect tires and check pressure,When you get it home you will want to establish a maintenance base line by repacking the wheel bearings and checking and adjusting the brakes.
If you are going to hire it done, and have the time, you might as well have it done at a local shop before bringing it home.
BTW; The deal is incredible!very incredible!, so check the floors, title etc.
If it is legit, then you can afford a LOT of repairs before even approaching fair value!
