QUOTE (peterh @ Oct 20 2009, 12:04 PM)
My bridge is 11" deep at the point where it meets up with the side cabinets, somewhat deeper as the trailer curves out over the window. You need to take that into consideration before you cut/build the opening for the side cabinets, and you need to take that measurement at the point where the bottom edge of the bridge will lie! If you don't do that and measure from the bottom corner your bridge will come close to or even cover some of your side cabinet door opening.
Also worth mentioning is I glued a double thickness of 1/4" ply in the face of the side cabinets where the bridge attaches.
The center section in my bridge is just slightly wider than a Monopoly board, the side openings (with the roll-top doors) are just over 11" wide. That makes the center section just right for (wait for it) board games and the side cabinets just right for storing the books and magazines we're currently reading.
Another suggestion I've seen, like, but ultimately decided not to include, was a downward-facing opening for a box if tissue. Cool idea . . . and I'm still undecided as to whether I should have made the opening or not.
Ok.... I hope this works!
Two times now I have written up several pages of reply and when I hit the post button I got an error and it was all goon. I think I may have finally fixed it. Thou I have pretty much forgotten what I was saying
Couple nights ago I got out to the trailer and was able to make some card board cutouts. And I was surprised how much work that ended up being. The next night I was able to cut out some ply for my first attempt to shape the wood. Now I have decided to use a 1/4" veneer simply because it was cheaper and a bit stronger than the other stuff I could find. It is actually an under layment but it does have a decent finish to it. Since I will be painting the cabinets with an acrylic (Epoxy something) appliance paint The grain style to me does not matter. So back to the cutting (Fun Part)
I stenciled out the first piece. I started on the driver side bottom piece first. After about 30 trips back and forth from the shop to the trailer I finally had it shaped up pretty well. I like the fit it is pretty clean. What I found amazing was the amount of sag and droop in my fiberglass walls. Nothing uniform AT ALL! But that aside I thing I have the process down. I picked up some 3/4 - 1/4 Rounds as you used and experimented with the layout for the corner. When I started to work on the shaping for the face piece I ran into a pretty good snag. My ceiling is drooping a bit in one spot. And I am not sure what to do about it. If I shape the cabinet to the roof it is going to look "FUNKY MONKEY"... I tried to push up on the roof and I was not really able to move it much. It appears that the factory cabinet over the cook top is the issue. The unit has the wrought iron supports attached and they appear to be actually pulling the roof down around the upper cabinet. I never noticed this before. So I will have to come up with something. Also I found some disturbing evidence of a roof leak that is leaching water under the ensolite. I will have to investigate that as well but I am glad I found it now rather than in spring. Yakima is a desert but it still gets pretty snowy here
. All that being said I was out in ye-old garage working on our new cabinets when my dear littlie wifey popped her head in to say hi and see what I was up to? She cheerfully reminded me that I have about 2,000+ (Slightly exaggerated) Projects that I need to finish before snow flys. That are far more important (And she is right) than our cabinet situation in the trailer. I got so excited about this project (that I have been wanting to take on since I bought the thing) that I forgot that I really don’t have time to work on it right now. I do so much appreciate all of the advice and assistance however. I will continue to post as I finish aspects of the project.
I hope that this thread is helpful to other owners in the mean time.
I wanted to take a moment to list a few of my comments on the advice given, as I have been researching this project for some time.
Hanging the cabinets - I believe that wood blocks or strip glued and or glassed to the cupboard drilled though and bolted with SS hardware is the best method for installation. Using wood will provide an even stress point load to the cabinet walls and bottom. Also wood will absorb and muffle vibrations and minimize vibration transfer into the fiberglass. This dampening effect is also reversed and vibrations in the fiberglass wall will also not be transferred as easily into the structure of the cabinet. This is less of an issue with the stock fiberglass cabinets due to the fact that they are the same materials and will vibrate ad the same frequency. Using a "bolt-though" design for hardware will in effect float in the hole though the wall. This will also limit direct vibration impact into the gel coat and substructure of the wall. Again, limiting the chance of gel coat fatigue and stress cracking. You can also tighten the bolts after a few months of travel because the wood and whatnot will expand and contract after a while. You cannot re torque pop rivets. (Correct me if I am wrong) -- Side note these are all very minor issues... My Scamp’s gel coat is so cracked it looks like varicose veins!!!
Sealing the holes - "butyl tape and stainless steel fasteners with SS washers" Agree all the way. I have dun the same with all of the other mods/repairs I have preformed. One word of caution: Stainless to stainless has a habit of galling. I recommend using a galvanized or nickel plated nut on the inside of the connection, on the stainless bolt. I would still use a stainless washer behind the nut to prevent later corrosion. Moisture seams to be a huge problem in my trailer... I have had some issues already with galvanized hardware. ( I use a catalytic heater at time present)
Not removing or slicing the ensolite - Also adds to the benefits of the afore mentioned. Shock absorption. Also I learned the hard way... On an older rig the stuff shrinks with time and so is tightly stretched around the walls.. When I cut a small hole for one of my minor mods it grew to a huge split. I had a dastardly time trying to fix it. I do not recommend trying to slit it or remove a specific section of it because It might be hard to hide the edges. Also in-tact is a good vapor barrier for the inside fiberglass walls. I imagine that cutting into it would allow condensation to gather behind, and if you are putting wood against the glass you could have a quick mold problem, not to mention rot.
Tissue Slot - I also had been toying with that addition. But I want to do something unique with it, especially since I am completely ripping off the design of the rest of it. I will post about it later if I can come up with something. But there is only so many ways to dispense tissue!
