QUOTE (MikeCM @ Feb 19 2010, 08:07 AM)
Dale what kind of leaks are you chasing? Window related? I had a few places where I thought I was getting leaks from the window frame seals, (and I may have been). I scraped out some of the butyl from the outside and used plumbers putty to make a smooth seal. But still had a lot of moisture, I sat out in the burro during a heavy rainstorm and noticed that the water was pooling in the bottom of the windows (front and rear). I pulled the lower track insert and found a lot of dirt build up. I could not see this buildup until I pulled out the plastic insert. After I cleaned the track and drain slits, I slid the plastic insert track back in. I have not had any leaks since. I had used the plumbers putty as a quick fix, as I knew I wouldn't have time to pull all the windows and get them back in. That was 20 months ago, and no leaks so far, so pulling the window frames is on the bottom of my priority list.
Not sure on the headliner depth on a u-haul, but on the burro there was plenty of depth for both reflectix and the thin head liner I used. I think it may have come very close to flush. Oh well there is always next time. The added insulation would have really helped up here in the northeast, but not to the point where I would pull the headliner off and start over. I'm sure there are many products that could be used, I just hated the shag carpet look (and after 28 years mine had somewhat stale and musty smell).
Good luck with the leak remediation, and I am looking forward the progress via pictures. I like the look of the u-hauls and that would have been my first choice, but any fiberglass egg is rare up here.
Mike
Hi MIke,
Well I finally got my trailer back from DJM in Hammond, LA... DON'T EVER USE THEM!!
They gave me an estimate of $50 per window to seal... they said they would take them out and use butyl putty to seal...
After getting a price of $110 per side window from Sunview, I decided that I would replace the sides and have the pros seal the front and rear. After keeping it for two weeks, they said that the rear was not able to be sealed but the front was done... I showed up there to pick it up and the guy was squirting silicone around the front window and had not removed it... I removed the inside frame and left it there... The following week I went to retrieve it and they had the front sealed. I had purchased some rubber/felt v-notch track for the windows from Perfect fit to seal the track for the sliders and they charged me $100 to install it in the back window plus $150 for sealing and "shop materials".
When I got it home, I got the hose out and tested it... the front is sealed but the rear and sides (with the new rubber track) also leaked...
At that point, I removed all the windows but the front and placed my order with Sunview in BC 250/494-1327. They only charged me $110 for the rear window (same as the side sliders).
After a conversation with Larry at Sunview, I followed his recommendation to get a solid rear window as opposed to a slider... He said that the vacuum at the rear might draw water in and I just want to have confidence of a dry bed... I bought some butyl tape and will be re-bedding the awning rails and am going to replace the marker lights with LEDs and rebed while I'm at it. The round tail lights are another source of water... they have the rubber grommets so I will be replacing them with a set of LED round lights with built in flanges, so I can seal around them and tighten them down to the body.
In the scheme of things, I'm glad to be replacing the windows... the 26 year old gaskets would have been very difficult to pull and seal on the side windows since they didn't have a frame like the front and rear... all three new windows will have a "sandwich" of an inner and outer aluminum flange that should make installation and sealing easier... the main thing will be to sand the gelcoat and clean clean clean with acetone, MEK, or both before applying sealant.
I have called the credit card company an am going to dispute the charges from DJM.
I already have the Avanti AC/DC fridge, new tiny window unit AC, microwave, foam, and upholstery on hand, but couldn't proceed untill I was assured of a weathertight platform.
Oh, I also got a new converter and fuse panel.... and a set of new hubs from Uhaul.
Lots of projects to complete before July.
Best Regards.
Dale
