QUOTE (Robert Johans @ Oct 19 2009, 08:33 PM)
Suger,
I replied to your post on the "Upper cabinet" thread. But I'll repeat it here:
Hello Suger,
As an owner of a 1988 Scamp, and given the amount of water damage you have already discovered, I would recommend inspecting (and replacing as needed) every rivet running through your fiberglass hull/shell. If it were my trailer, I'd pull everything out of the inside: furniture modules, wall coverings, as well as all of your windows. This way you can see exactly where all of the damage exists, as well as the possible source of water leaks.
This may seem like more work than you're willing to do. But your upper cabinets, kitchen/galley unit and vertical cabinet are all held onto the shell with rivets, which over time become primary sources of leaks. I replaced all of my rivets with stainless steel bolts and nuts. Plus, generous amounts of butyl putty to insure a good seal. (In fact, you can use butyl putty for ALL of your sealing needs. Don't use silicone!)
About your upper cabinets: the originals already have appropriate holes (top and sides) for hanging. There really isn't any good reason to use the curtain rod holes, UNLESS (as Larry did) you are replacing the original upper cabinets with something completely custom.
RJ
thanks for the reply robert, and yes I have gutted the little scamp,
to date I have pulled up the elephant hide/skin and located that the table support board is shot/ a leak, a leak in the belly band area by i think you call it the street side (sink side), so the wooden fiber glassed bech supports ar shot, and when some one installed the vents for the frig (Dometic, gas, 12V & 110) it leaked around the metal access panel and the floor is damaged.
I am beginning to suspect those pesty curtain rod holders too.
My continual mentaldebate is I like that rubber type covering and would like to find a source for replacing it, well leaks first and I have time to figure out the covering
I replace the floor and it was really tough to fit it in between the fiberglass channel but it workrd and I have re-glass over that. Fiberglass is new to my repertoire, so I am taking baby steps,
the little scamp was made into swiss cheese with screws and silicone (what were those people thinking?) I plane to fiberglass on the inside and use a 3m product I found at the boat store. I am sure after plugging up all these holes I will be gun shy about drilling any. that is why I have been reading up on the proper way to attach stuff.
My husband, Adrian wants some type of awning and maybe an outside light and shelf.
I have been thinking of ways to change sleeping positions so you don't have to crawl over each other
I have taken photo's I'll try and get some one to teach me how to up-load them Thanks for helping suger
