QUOTE (mszabo @ Nov 1 2009, 10:09 AM)
That's what I'm looking for with door.
Let me know.
I live south of Jackon but, I'm in Lansing alot and can pick up.
Thanks, Mike
Hi Mike. I got the water heater out of the motorhome tonight. I hooked up a reg and gas tank to test it out. Within a few seconds the pilot lit up. After another minute I turned the dial to "on" and away it went! the flame looked good. I only ran it for a few seconds because of only a little water in it. I turned it back to pilot and back to on several times and it never failed to light. Whenever I get a chance I want to fill it with water and fire it up to see if all is well. The dimensions of it are 20 1/2 inches from front, the control end to the rear. The width and heigth are both 12 5/8 inches. I was able to get the door frame off without damage and I found the door too. The hot and cold water lines are on the rear end. They appear to be 1/2 inch pipe thread. The gas line connection is 3/8 flare copper tubing. The outside of it is nothing more than a galvanized tin box. The bottom side was sitting just a 1/4 " thick piece of scrap paneling. The sides were about 2 1/2" from cumbustible wood inside the closet. About the same on top. The only thing I would be concerned about is the condition of the preasure relief valve after all this time. It may work just fine but I think I would replace it. If it all checks out when I fill it and fire it, I would like $50 for it. I have a daughter that works in Mason and if all goes OK you might be able to pick it up where she works whenever we see her again. The tiolet seems to be functional.I dont know if non use is detrimental to seals and valves or not. I'd take $20 for that.
You can call me at 989-433-2637 after 4:30 most nights. Rus
