You can make plain screws look a little better with inexpensive finishing washers found at hardware stores or building centers. Available in different sizes, they can be used with tapered seat wood screws or machine screws. They really increase the holding power of simple screws. If you have had a problem with loose screws causing the holes through fiberglass to become elongated when your trailer is bouncing down the road, use these to eliminate that! see illustration
