I don't recall seeing anything on this in recent history. What sort of door seal does Scamp use from the factory? Our 13' has/had an open cell foam rubber strip stuck around the door opening. I don't know if that was original or installed by the previous owner. Due to the leading edge of the door dragging on it when closing, it had already migrated away from where it was originally attached in some places. We've never had a leak problem, but it just looked ugly. So I tried installing some foam weather stripping from Lowes that has a smooth sealed surface where it contacts the door. That stuff has migrated forward in some places also, until it's at the edge of the recess for the door. Maybe two strips applied side-by-side would prevent that from happening. This seems to be one of those "don't look too closely" things. I'm not sure the door actually touched the weather stripping in some places anyway, especially toward the bottom. We've never had a leak, but I would really like to make this look better. I know Casita uses a tubular seal attached to the door, not the body, which seems to work very well. It would sure be nice if Scamp did something similar. Ideas appreciated, or at least some comments on what sort of seal Scamp installed originally.
Parker
