Worser and worser!! The installer at UHaul checked the wiring he installed (also showed me, it was very simple, just plugged in OEM Nissan harness that I bought and supplied to factory installed plug) and checked the power with brakes on/off at the outlet on the TV. Everything checked out good. I still had all lights working and no more blown fuses, but still no brakes.
Since I hadn't heard a negative on this, I decided to take off for AZ without brakes. Stopped at a rest stop about 1.5 hours into Illinois, checked connections and felt the trailer wheel hubs. The right hub was warm, but the left was hot. Now, I was driving with the left side of the trailer in the sun, so hmmm... Mind you, I had the bearings and hubs replaced two months before the trip and since then it has been sitting in the driveway. So I drove another hour and felt the hubs again. The left one was too hot to keep my hand on for more than 1-2 seconds. I called nearby Crossroads RV and arranged to tow there after an hour (their techs were out on a call).
When I got there (about 2 miles), they said the hub was no longer hot! But they checked the bearings (well greased), jacked up and turned wheel (freely) and looked at the brake shoes (little wear and properly seated). But with the wheel turning freely there was no response when I touched the truck brakes or used the manual lever on the brake controller. Same results when they hooked up to their truck with a good Prodigy brake controller.
SOOO, I left the trailer with them to replace the Bargman plug and wires back to the brakes on the trailer and came back home for the night.
New problem: the . or .. or .nc(when I pull the manual lever) lights on the controller were green but now are red. I can't find any reference to color in the manual. Today I will call Tekonsha tech support to see if they have any word.
EDIT- I just played the video for the Prodigy and it shows the numbers in red, so either I imagined the green, or it is supposed to be green when not connected. The video shows changing the power from 1 to above 7, but my controller will not go below 6.1 when I try to set the power. I am starting to suspect a bad controller (one of the options listed in the FAQ at Tekonsha website). I think I will unplug the controller and continue on after the rewire.
Another question: what ELSE could cause the hub to heat up besides loss of bearing grease or dragging brakes?
