QUOTE (Ed Harris @ Nov 12 2009, 06:13 AM)
That was a good explanation for sure but I have found that many older trailers and smaller ones have no real converter section at all.
It may be that you are simply charging the battery with the charge line of the vehicle through the seven pin connection to the trailer when connected?
Is there any reason to think you are doing anything different plugged into AC other than powering the AC outlets directly?
You mention that you think it should power the furnace better but you do not say if you have done so and if it does?
My first trailer had no electronics in it at all.
If you can not find a converter/charger maybe there is none.
Ed
Ed:
While I don't have the specification for the Burro Wide Body, if you look on
http://www.burrotrailers.com/deluxe_options.htm it appears that a converter was an option in 1998, and presumably in 2000 for the Burro, and the trailer was described as having an inverter, which I took as being a converter. I didn't think the problem was whether the trailer had a converter but how the switching occurs so that when the trailer is plugged into 110 volts there is 12 volt power. My understanding is that this is something that the converter looks after: when you are not hooked up to 110 volts the furnace runs from the battery. When you are hooked up to 110 volts the furnace is powered by the converter which also charges the battery.
Brian
