Full Version: Uhaul table mod proposal, input please
Pat B Ohio
Since I like space, I was trying to figure out what to do with the big table in the bed area. I thought about doing a double drop leaf making the pedestal table skinny. Has anyone done this? or am I better of just making a lounge area?
I am doing the front table mod. My 17 yo teenager keeps asking where he is going to sleep......tee heee.
CindyL
When we had our Burro, we just had a piece of plywood that we removed during the day to keep the area open (We also added a front dinette.)
CindyL
Pat B Ohio
Cindy, you have a bigger trailer than me and you vote for the "Lounge" application. I think I could easily stow the 2 32"x16" boards for the bed in one of the benches, but having a big table would be nice.
ThomasE
The rear dinette table of my Burro was in a permanent bed configuration before I bought it, and I'm leaving it that way. But to get to the storage compartments on either side of the rear bench I have to remove the table platform, and at 44x32 or so it kind of hard to move around because of it's size and weight. So I cut it in half and added a $12 piano hinge in the middle so I can fold it before moving it. It's a lot easier to move out of the way now, basically I can fold the table top and put it and all cushions on one of the benches, and sit on the other one. The top is still heavy since it's particle board, but easier to manuever and get in and out of the trailer. I might replace it with lighter weight plywood in the future.
Raya L.
This doesn't address having a rear table, but since I primarily use the rear area for a bed, I removed (and saved) the table and instead use a few 1" x 8" pine boards (about 29" long in my case) to make up the center part of the bed.
Nothing magical about my choice of "x 8's" -- I just happened to have them on hand from some bookshelves I made but was no longer using. But what I like about the boards is that they are easy to move around and store. And I can change the size of the bed in increments.
The original table in a Boler is even more unwieldy than in a U-haul because, without a back bench, the table is full-depth.
Raya
CindyL
Pat:
This is not what we do with our UHaul. For our current trailer, the UHaul, we leave the bed put up. With our previous 13' Burro, we always took the board out and the bed down during the day, so the Burro would have more space. There are only 2 of us, so we used out front table mod for eating.
CindyL
stephanie reed
Click to view attachmentClick to view attachmentClick to view attachmentMy camper has a small table you can remove. I use two pieces of wood to use for the bed that can be stored under the cushions. The table uses the poloe in the floor and has a fold away leg that props up on the cushion to stablize. The only drawback is where to put it when not in use.
Pat B Ohio
Stefanie, I like the design of your table. Maybe we could add the slide from Judith's mod and make it fit the bed drop, leaving only the addition of one board for sleeping....
54.gif Lots of great ideas....maybe too many to choose from.
CindyL
Pat:
Do you have your original dinette table? If it fit in our VT, it might be nice to replace our plywood with something more original if you were interested in parting with it. Our dinette table was missing when we bought the trailer. PV had put the bed together permanently with this plywood and had a huge water tank under the bed.
CindyL
