I discovered yesterday that the bolts at the front of my Trillium, under the bunk are not doing anything. They are just filling space in the hole with no nuts attached. That's a bit scary. I searched along the steel tube frame for other empty holes but found none. I am assuming that the rest of the bolts are lags which only go through the top of the steel tube. Inside the trailer there are a few empty holes in the fiberglass above the frame that have been filled with silicone...also scary. This has just become my first priority. I found rectangular U bolts at Home Depot that are 5/16" x 2" wide and 5" long. I think they'll fit nicely around the steel tube and be a good alternative to drilling into the steel All the holes look like key holes and I don't want to add to the damage. I will put one at each side under the front bunk where the original bolts were and two on each side under the rear seats. I'll install them with a large plate washer to spread the pressure out and lock washers. Does this seem like a reasonable solution?
Another thing I've been looking into is the interior liner. The stuff that is there now is NOT ensolite but fiberglass (like the insulation in your house walls) with a vinyl skin. It needs to be replaced. Has anyone ever used a foam undercushion for carpeting? It is a closed cell foam that I think must be similar to Ensolite but without the vinyl skin. Ensolite type material seems to be very hard to locate, I need an reasonable alternative.
