QUOTE (Judith Kennedy @ Nov 17 2009, 08:24 AM)
...Then we expect to mount a 125 watt solar panel on the luggage rack of the van to run the frig, and via a cable, keep the camper battery charged as well. The good part of this is that there is room on the van for the panel, and we can park the van in the sunshine while the camper remains in the shade. In addition, the panel can be positioned to face the direct rays of the sun by adding a tilting mount.
A selector switch will select the load between the panel and the TV alternator as required.
We welcome any comments, good or bad, as to the practicality of this idea because we only THINK that's what we want.
I'm not exactly clear on your setup. It appears your deep cycle battery is, or will be, in the trailer, and not in the TV(?).
If you hook up the PV panel to a controller located in the TV, then hook up the charge out from the controller to the battery in the trailer, and then connect the load terminals on the controller to the fridge, then you'll lose power to the fridge as it gets dark, so no power overnight.
However, you don't need to use the "load" output from the controller. You can hook the PV to the controller, and the controller's charge output line to the battery. Then you hook up the fridge to the battery, along with any other loads (lights, furnace, etc.). These are then in parallel with the panel. You would then need a 12v power line from the trailer to the fridge in the TV. Maybe a short line for when under way, and a longer one for when the TV is parked in the sun. Or maybe just coil up the end of one long one while under way.
Actually, 24 amp/hrs per day
can be a lot for a deep cycle battery, and more so if you need to run electric lights, television, computer, furnace fan, or whatever else. But, one rule of thumb is for the battery capacity to be 4 times the expected daily usage, so if you have a 100 amp-hr deep cycle battery, and don't need to run anything else, you should be OK. Depends on other variables, but a 120-watt panel should put out enough to replace the usage, on most days. I think.
At any rate, you should do the math, and add up all your expected usage, and determine your required battery capacity and required charging ability accordingly. One major factor is that at some point, around 70-80% of full charge, the battery can't accept the full output of your panel. The charge rate slows down dramatically, and if your charge controller doesn't compensate by reducing the output of charging amps, the excess output will only go to producing gas and boiling off the water, both of which are bad for the battery. Of course, if you're running the fridge at 4.5 amps, and the panel/charge can put out 10 amps, you have up to 5.5 amps for charging the battery at the same time. Another factor is whether you plan to be out for long periods of time, or just 2-3 days max, as you could gradually run the battery down to 50%, then bring it back up to full charge after you get home.
There are plenty of books and web sites that provide detailed information and worksheets to help you calculate your battery capacity and charging capacity requirements fairly accurately -- at least accurately enough to avoid problems once you get out on the road. One book that I can recommend is
Managing 12 Volts. How to Upgrade, Operate and Troubleshoot 12 Electrical Systems, by Harold Barre. It may have more than you need to know, but it does simplify the process of determining your requirements, and keeping your system working well.
Sorry - I got a little carried away. Hope this is helpful...
