QUOTE (peterh @ Nov 18 2009, 01:59 PM)
Our Scamp came with a single valve that shuts off the flow into the water heater. Works for us!
Where do you put the drain ballcock? Does it go in-line with the bottom water heater plumbing connection? I'd love to drain our water heater without having to un-wire the HottRod electric heater element that installs into the drain port.
The drain goes on the outside at the water heater panel. I couldn't find a clear picture of the Atwood drain, but it's basically at the front panel, lower left corner. Right now there's a half inch drain plug there, I have to use my 7/8" lug wrench to get it out so it's kind of a hassle to drain. Peter it sounds like you have a an electric heater so I'm sure it's configured differently from my propane one. This is a picture of the drain Camco 11703, I just ordered off ebay for $3.75 + $1.90 shipping. Hopefully it will be drainable without tools now. Good idea about the valve on the input line, I thought about that, and it would be cheaper to get a Pex compatible barbed 1/2" ball valve.
