12V electric scissor jack - $49.99 CDN - Fiberglass RV
Old 04-26-2008, 11:56 AM   #1
Roy in TO's Avatar
Online Catalogue
For those of you who like gadgets.
Old 04-26-2008, 01:00 PM   #2
It may be a gadget to some, but I wouldn't go camping without mine.
I use it to :
1) Change tires,
2) Adjust brakes,
3) Rotate tires, and
4) Relevel Casita when camped on soft ground.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 04-26-2008, 03:34 PM   #3
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
I 'had' thought of buying 4 of these for our trailer, but the combination size of 4 of these would be probititive. What we've opt' for instead is 4 used (auto dismantler's special!!) Honda car jacks. I have cut the end off where the crank handle would normally fit in and welded on a 3/4 in nut. We have a Sears 18. whatever V. sized assortment of tools including a portable flourescent light and a vacuum which we always carry anyway. The lugnuts on the Trillium are 3/4 as well. I have welded a 3/4 in high impact socket to an extension to fit in the end of the drill. Now I have four portable jacks which I can place where best suited and an electrical lift sysyem to use with them. Changing flats is no longer an issue as jack(s) can be placed where best suited. All for of these jacks p(lus the drill with attachments) fits into a home made polished aluminum box (with no lid) that we keep right inside the door while traveling. This box is always the FIRST item out of the trailer when we get a spot AND the box, when empty plays double duty for the Trailer Goddess as we use the inverted box (the side with no lid) as a step for SHE, who is also 'vertically challanged' with her demeur (do I merit marks for NOT saying 'SHORT'???) little nubbies!!!
Old 04-28-2008, 04:45 PM   #4
Roy in TO's Avatar
This vertically challenged individual thinks thatthere is the distinct potential that you may perhaps be, how can I say this ... spelling challenged. Unless of course the left coast spells things differently.
CD Smith ... I own two of the manual versions of this "gadget". In addition to your uses, I've found mine very helpful where the ground is uneven and one or more of the regular levelling jacks is just too darned tall to get under the frame.
Roy
Old 04-28-2008, 10:41 PM   #5
Doug Mager's Avatar
Roy
Well, for starters LOL, out here, on the BEST COAST its called Toranna
Old 04-29-2008, 05:38 AM   #6
james kent's Avatar
Trailer: Boler 1984
I, also have two of the recycled Honda jacks at less than 1/4 the cost of one of the electric ones. Doug, I like the idea of welding a nut on the end of the shaft that matches the wheel lugs. Right now I'm using the rod with a crook that came with the jack and an extra drill brace that I had in the workshop. Sometimes it can be a bit awkward depending on terrain. I usually carry a socket set so adding my cordless wouldn't be too much extrato take along. As long as I remember to charge it up before leaving home.
" SHE" says that I have a mind like a sieve. I think that vertically challenged may better than memory challenged. EH?
Old 04-29-2008, 02:07 PM   #7
Roy in TO's Avatar
Having a "senior moment" is apparently socially acceptable in this day and age.
Too bad I have not hit that point in life where it is an acceptable excuse,
that leaves me both vertically and memory challenged.
Old 04-29-2008, 02:45 PM   #8
Doug Mager's Avatar
James, we get soo much usage of our 'system' that now we take two batterys and the charger along. You might find the drill system a little weak unless you have good, fully charged power source.
Old 04-29-2008, 04:26 PM   #9
james kent's Avatar
Trailer: Boler 1984
Guess that I'll stick to the hand drill. It's almost like having a speed wrench and I'll still keep the weight down. We don't usually have hydro so not much sense carrying a charger.
Old 04-29-2008, 08:19 PM   #10
Doug Mager's Avatar
Well James What Can I Say ?? Whatever Turns Your Crank...
Atwood Fifth Wheel Jack - Electric Motor instead of Hand cranking Gail Shook Care and Feeding of Molded Fiberglass Trailers 12 07-31-2013 06:26 AM
Electric A-frame jack on sale at Princess Auto Cam A General Chat 10 05-26-2010 06:47 AM
Electric jack? RSchleder General Chat 3 05-19-2010 08:27 AM
Electric Tongue Jack Opinions: Atwood vs. Ultra Fab Jane P. Care and Feeding of Molded Fiberglass Trailers 31 01-16-2010 01:41 AM
Electric Tongue Jack Donna D. Problem Solving | Owners Helping Owners 23 02-15-2006 06:26 PM
