12v electrical - Fiberglass RV
Old 10-17-2017, 10:54 PM   #1
12v electrical
I lost some 12v power to a circuit I checked everywhere tore the bed apart on the scamper. After a lot of checking and no results I couldn't belive it so I went to the battery no 12v reading on my meter but had lights in the trailer.
after looking at the meter I had it turned backwards that is about incompetent!
now I am busily tracing my line matter of fact now found the problem and will be fixing it tomorrow!
bob
k0wtz is online now   Reply With Quote
Old 10-18-2017, 06:05 AM   #2
Ed Harris's Avatar
12v electrical
Nevermind
Old 10-18-2017, 08:06 AM   #3
never mind
I see no problem ed
thanks
bob
Old 10-18-2017, 07:42 PM   #4
fixed
well the 12v circuit is fixed for some reason a diode light would snap on and go off so I had to go to another wiring set up.
12v wiring is strange at times. very hard on a guy with recent back surgery but its done now!!
bob
Old 10-21-2017, 12:01 AM   #5
Trailer: 1990 Scamp 16 & Vanagon
Idaho
So I assume you are using the simple method of a light on a wire to test if you have power. And this light is an LED, or you replaced with with an LED.
Do your self a favor and pick up one of these.
harbor freight has them often on sale for 4.99 or even free. You can also pick them up on Amazon. You can read the true voltage reading of the battery, if you connect the leads backwards it just reads the voltage as negative (but that does not matter). You can check current draw (put the leads in line with the circuit). Everyone should have one in their tool kit.
1500 is offline   Reply With Quote
Old 10-21-2017, 11:15 AM   #6
Virginia
1500 has the answer.
You can not connect it backward because if you do it says -12. If correct says 12.
Neto is offline   Reply With Quote
Old 10-21-2017, 01:30 PM   #7
meters
I have about 6 of these when I can find them. I use them all the time for all sorts of el. work!
why buy when they are free free free!!
bob
Old 11-13-2017, 10:00 PM   #8
Borden's Avatar
Name: Borden and Carole
Wiring is always fun as we speak front 5 top cleasence lights have quit. Meter time, know they are chained lol
1978 Ontario made Boler
Old 11-14-2017, 07:15 AM   #9
Madison, Wisconsin
I think you are on the right track to get out your meter.
Outside lights often develop poor connections since most of these fixtures don't keep out water very well, especially at 60 mph. Taking off the lens and polishing the contacts and adding a bit of dielectric grease (or Vaseline) makes it all better. But, 5 at a time are more likely some kinda fault in the wiring. Time to explore with your meter as you say.
Good luck, john
Pic of Lake in the Clouds at Porcupine Mountains State Park in Michigan's Upper Peninsula.
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is online now   Reply With Quote
electrical
Electrical-can't get my electrical heater started. robertmarchiony Problem Solving | Owners Helping Owners 6 09-08-2017 07:11 AM
Run 12V TV/monitor off of 12V outlet or via inverter? Rod Scher Problem Solving | Owners Helping Owners 22 11-19-2016 02:11 PM
Run both 120 & 12v electrical jimkill Modifications, Alterations and Updates 17 07-31-2013 03:33 PM
12v electrical panels ken h Classified Archives 7 09-10-2009 12:40 PM
Electrical Questions of the 12V variety Bonnie Electrical | Charging, Systems, Solar and Generators 6 01-04-2008 11:00 PM
» Virginia Campgrounds
