17 ft size towing? - Page 2 - Fiberglass RV
Old 04-02-2006, 05:11 PM   #15
Trailer: 2002 17 ft Casita Spirit Deluxe
I should qualify the mileage figure - that is not towing the trailer. While towing we get around 15 - 16 mpg. Curiously, the mileage figures towing with several different vehicles are pretty close to being the same. What you will appreciate is the better figure than what you would have from some humongous stick built rv. We once camped next to a huge bulgemobile with expanding sides for a 12 ft wide living room, asked the guy what he got for mpg highway. All he said was 'you don't want to know.' Don't think you will be reluctant to reveal yours ! Don
Donald Stahl is offline   Reply With Quote
Old 04-02-2006, 06:42 PM   #16
BOBSMITH's Avatar
Trailer: 2002 Casita Freedom Deluxe / 2007 Nissan Frontier King Cab
We tow with a 1999 Nissan Frontier with a V6 4WD. We get about 18mpg when towing our Casita and the truck bed fully loaded, plus our 15 foot canoe.
We keep the cruise control about 60mph, sometimes creeping a little higher than that. We slow down on steep inclines going over the high mountains up into the NC/VA/TN/WV/GA high country.
BOBSMITH is offline   Reply With Quote
Old 04-02-2006, 08:01 PM   #17
Brian B-P's Avatar
Perhaps one factor to keep in mind is trailer width. The Boler 1700 that I have (like Benny's) is a wide-body: it's a foot wider than the typical narrow-body egg. The Scamp, Casita, and Escape 16' to 17' units are all narrow-bodies, while recent (1500-series, 2500-series) Bigfoot models of similar length are wide-bodies (even wider than the B1700). Apparently Burros come in both widths. Since air drag is very important at highway speeds, width (which determines frontal area) matters.
Old 04-03-2006, 07:06 AM   #18
Trailer: 86 Burro 17 ft Widebody
17' Burro wide body, 2400 pounds. 2004 F150 2WD super crew, 5.4L, 3.73:1 rear axle ratio. 13-16 MPG at 60 MPH. At 65-70MPH the mileage will drop to 11. I learned that the 3.73 gears really make a difference if using cruise control. This truck will just keep pulling in OD without downshifting. I look at the slight fuel penalty as cheap life insurance. It also reminds me to keep the speed down.
Rick
Rick F. D. is offline   Reply With Quote
Old 04-03-2006, 10:19 AM   #19
I`m guessing that if I had a 3.73 gear instead of my 3.42, I`d notice the difference....the next one would be a 4.10......problem then would be I`d have to feather the throttle more when taking off when empty,LOL......Oh...gross trailer weight for my truck is 6100 lbs. with a GCWR of 11,000 lbs. ....my truck is my primary transportation but if I decide to get a car and use my truck basically to tow only, then I may change the ratio......Benny
Old 04-04-2006, 10:07 AM   #20
Administrator
Mary F's Avatar
Anybody have experience backing a 17 footer uphill on a gravel road?
Our 4.0L Ford Ranger manages our 17 ft. Casita just fine, except for when we get home and cannot back it up our gravel driveway.
Twice now, we've had to unhitch and connect it to the F-150 to get it parked... (The Ranger has tow package and limited slip differential, whatever that is. The F-150 has no package, similar horsepower, but bigger tires, better traction.)
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 04-04-2006, 12:20 PM   #21
Sounds like you need more weight over the rear axle of the Ranger Mary. The F-150 has a higher weight ratio to the trailer than the Ranger. Pickups are generally light in the bed area, a couple of bags of tube sand thrown in the back of the Ranger would probably take care of the problem.
Old 04-04-2006, 12:21 PM   #22
Brian B-P's Avatar
Mary, I would guess that the F-150's advantage is simply weight on the drive wheels, not the tire size. Weight = traction.
A limited-slip diff (LSD) limits the amount one tire spins by partially locking the left and right sides of the axle together - great if one tire has less traction (poorer surface, for instance) than the other. With a limited-slip, you aren't so limited by the worst-off tire, but if both tires are working together and still don't have enough traction (both spin), the LSD isn't enough.
The problem is the backing up: with the rig facing downhill, the truck's front axle carries more load (and the rear axle less) than while level - that's load transfer. This means less traction for the rear axle to drive with. I have had the corresponding front-wheel-drive problem: traction is reduced when going forward uphill. Certainly, this is a practical limitation to the towing capacity of two-wheel drive vehicles: how much of the rig's total weight is on whatever tires are being driven?
I find it interesting that weight-distributing hitches (WDH) exist to transfer load away from the rear axle (onto the front axle and trailer axle), so with a rear-wheel-drive vehicle it makes drive traction worse; with a front-wheel-drive, the WDH would make drive traction better. If I had the backing problem with the Ranger, and was using a WDH, I would slack off the WDH as much as possible (without violating the rear axle rating) to improve traction in this situation.
I already had "I have no idea if Mary is using a WDH or not" in this post, but now that Mary has responded I'll point out that since she doesn't use a WDH, this part is not relevant to her. (I also edited the formatting of this post for clarity).
In my case, when loaded, the front and rear axles of the van carry almost identical load, so it would not matter which end gets driven except for the hill issue, and the fact that load transfers from front axle to rear when accelerating.
Old 04-04-2006, 12:47 PM   #23
Administrator
Mary F's Avatar
Yeah, or maybe some of these spare limestone blocks we have laying around our yard.
Or we could just pave the driveway...
Or not sell/give away the Big Blue Gas Hawg.
And, no, Brian. We don't use a WDH. But thanks for guessing that we do.
bed size??? curtis c General Chat 1 03-04-2009 02:53 PM
Bed Size Legacy Posts Care and Feeding of Molded Fiberglass Trailers 30 01-18-2009 08:09 AM
Need some help, ball size & towing Arline Lovell Towing, Hitching, Axles and Running Gear 10 06-08-2008 02:59 PM
Bed Size Rob M General Chat 8 03-26-2008 03:23 PM
