17ft Bigfoot. Info. - Fiberglass RV
Click Here to Login
Old 06-13-2016, 02:05 PM   #1
Trailer: 1975 boler
17ft Bigfoot. Info.
Hi there. So I have been thinking about buying a 17 ft Bigfoot. Used. Probably an 80's if I can find one. I had a 13ft boler for 5 years and then sold it had lots of fun with it. Want to get back into a Bigfoot with a bathroom.
So when out shopping ,what should I look for ?
Any common problems ?
How are the frames ? Are they weak like the bolers ?
Thanks for any info.
hittinghard is offline   Reply With Quote
Old 06-14-2016, 10:05 AM   #2
Trailer: 1988 B19 BIGFOOT
BIGFOOT B19 1988
HELLO Happy owner of a Bigfoot for 4 years. When I bought my 1988 B19 I brought it in and had the brakes and bearings re-do, checked wiring. The previous owner had wires everywhere! Made sure gas lines were in working order and then started using it! Little by little I am taking care of some cosmetics. Check out the floor too - see if you feel any soft spots indicating previous repairs maybe from water damage. I love mine! I don't often post or reply here and I know there are other more experienced members that can help you out.
Debi W
Debra Wagner is offline   Reply With Quote
Old 06-14-2016, 03:51 PM   #3
Trailer: 2017 Escape 19
We have a 1987 Bigfoot and have been quite happy with it. We're the third owners and have been enjoying it now for about six years.
Some people have had "delamination" issues with the older units. Bigfoots are constructed a little differently than other fiberglass trailers in that they have a sandwich construction consisting of the outer fiberglass layer, a rigid foam insulating layer and then the interior paneling. These layers are glued together and make for a very strong shell - as long as the glue doesn't deteriorate. It's my understanding that the original Bigfoots were made with a glue that was not waterproof so if there was any water intrusion things could start to come apart. I don't know for sure when waterproof glues were introduced. We've had some minor problems with this issue on our trailer, but nothing that prevents us from using the trailer or that we feel is a safety concern. You might want to look at this thread: http://www.fiberglassrv.com/forums/f...ion-42251.html and this one: http://www.fiberglassrv.com/forums/f...oot-38073.html Some people have had sagging roofs too, but ours seems quite solid.
I know of no particular axle issues unique to Bigfoots.
Good luck with your search!
Evergreengirl is offline   Reply With Quote
Old 06-15-2016, 02:46 PM   #4
Trailer: Bigfoot 17' DLX
Alaska
Bigfoot frames are very sturdy. On an older one make sure you inspect the shackle mounts as the weld where they are attached to the frame can break. Easily fixed though.
The early BFs have Qest plumbing. Make sure you inspect the entire system carefully. This was the single biggest issue I had with the 1989 17-footer I bought, probably due to freeze damage. I ended up redoing almost all the plumbing with PEX but it's not your typical DIY project. If you can avoid re-plumbing the trailer, you'll save yourself from a lot of headaches.
Axles, leaf springs, windows, vents, entry door, and most appliances are easily replaced with new, off-the-shelf items. It's the proprietary BF parts that are not so easy to replace, such as fender flares, propane tank covers, gravel guards, cabinetry and trim, upholstery, etc. Make sure those are in good shape.
trainjunkie is offline   Reply With Quote
Old 06-15-2016, 04:22 PM   #5
Trailer: 1975 boler
OK thanks for the replies guys. I was just trying to see what bathe common problems where. Maybe something I would over look or something I wouldn't think would be an issue. Nothing like a review from people who own one. As for running pex lines I would be able to do them myself and anything else that breaks or needs fixing. I used to be an rv tech. Went to collage and all that for it. Anyways. How are the floors ? Are they fiberglass or are they plywood ?
Sent from my HTC One_M8 using Fiberglass RV mobile app
Old 06-15-2016, 04:47 PM   #6
Alaska
Bigfoots have 1-piece top and bottom halves so it's like a fiberglass "tub" with a plywood subfloor. I believe there is an air gap between the FG and the plywood. Here's a shot of the subfloor in mine when I was replacing the entry door, and the entry-way linoleum, which had curled from previous water damage.
Old 06-15-2016, 05:14 PM   #7
It's quite likely the water came into the trailer from the bottom of the door frame. The corners of the aluminum frame are sealed with something similar to gutter sealant and that seal can open up after time. When I got my trailer there were cracks there but the trailer had been stored inside so there was no water damage. Resealing the door frame joints was very easy. I did have some rotted wood in the entry door itself. The water intrusion was just in the door itself. The door is made from panels with foam insulation in the center and a wood frame around the perimeter. I took treated wood and cut it to the size required. If you have basic carpentry skills and a table saw, its about a three hour project.
Old 06-15-2016, 05:51 PM   #8
Alaska
My door frame had some mildew but, thankfully, no rot. The interior wood frame of the door, however, was rotted completely, especially the lower third. I suspect the water entered the door through a large crack in the exterior fiberglass panel that was there when I bought it.
I was only days away from a fall camping trip when I discovered this so I didn't feel that rebuilding the door was a good use of my time. Instead, I just bought a new AP Products 24x68-inch entry door, which was an exact fit and less that $400.00. I could only get a bright white door so I did prep it and paint it to blend in with the Colonial White trailer, which only took a few hours of work. Turned out to be one of the best upgrades I ever did to the trailer.
Old 06-15-2016, 06:33 PM   #9
That's a nice looking door and for the price, if it came with the window and latch, a great price..
Old 06-15-2016, 06:48 PM   #10
Alaska
Jack, the AP entry doors are turn-key with the window, deadbolt latch handle, and the interior screen door. I did change the handle from white to chrome because I didn't want to attempt to paint it. But that only cost another $25.00.
It's amazing how many current off-the-shelf components still fit these early Bigfoots. There is something to say for standardized components when you are doing a restoration.
Old 06-17-2016, 01:36 AM   #11
Trailer: 1975 boler
How are the furnaces ? Btu's enough to heat it or does it work over time .
Old 06-17-2016, 06:58 PM   #12
Alaska
I installed a 18K BTU furnace in mine and camped in -10F temps with no issues. I did not use the water or wastewater systems though. My BF did not have thermalpane windows so I put Reflectix over the glass for more insulation. Worked out just fine.
Old 06-17-2016, 09:01 PM   #13
OEM furnaces.....
IMO the OEM furnaces (very common in LOTS for RVs of the era and even to this day) are a downer...oh they will heat the place alright but consume TONS of electrical power while doing so.......it's a shame really...just to be dissapointed just go outside and feel the heat (LARGE amounts of it) that is coming out of the exhaust......myself, and most owners I think, run the furnace until they go to bed....then start it back up again a half hour before getting out of bed.....
Bigfoots in general are heavier, wider, less aerodynamic (more fuel used towing) than most FGRVs around here.....they also have more room inside and more storage.....generally spreaking the FG shell is thick and there is some insulation in the walls/roof other than just the standard "rat fur" in a lot of FGRVs...
I "overpaid" for mine....invested/had to fix quite a few things.....I'm going to have mine for a VERY LONG time....not because I'm looking for my money back...because it's PERFECT...for me...happy motoring
Old 06-18-2016, 08:01 AM   #14
ZachO's Avatar
Trailer: Sasquatch
Montana
The furnace is just fine. However it's a...I think 12,000 BTU furnace in a 17ft trailer. My little tiny Toyota Chinook had a 16,000 BTU furnace. Which was total overkill. But coming from that, to this very spacious trailer with "only" a 12,000 BTU furnace took adjustment.
You don't get up to 70 degrees in 5-10 minutes. It's more like a house furnace, where it brings you up to temp nice and slow. It's completely adequate, but if I found a reason (and the cash!) to upgrade, I'd get a 16,000 BTU in there. I don't even think they make the 12,000 models anymore.
But a new furnace will cost $500 and is unnecessary, unless you do serious winter camping on a regular basis.
I too came here asking if there were any specific tips/tricks/issues with Bigfoots. Didn't find much. As a shell, they are solid, though it's already been brought up that the earlier ones can suffer from some roof sag. Everything else is typical RV components, made by various manufacturers. Dometic fridge, Atwood furnace etc.
Probably you'll need to replace the power center, as it seems the battery charger will fry your battery. They're just old enough that they don't switch to float mode when sensing your battery is full, and keep charging at full power.
I don't plug in much so I've put that project off for now. It's on my list though.
Sounds like there's a consensus that they tow nice, very stable. They aren't aerodynamic. But mine tows really solidly. No sway, stays nice and under control.
I love it. For it's very simple, boring shape, it actually draws more attention than I'd expect.
So..."Issues" you may find yourself spending money on after buying it, that you might not have expected:
-New power center/converter/battery charger
-Possible axle upgrade - stock axles have it very low to the ground and more clearance is a requirement for some. But not all.
Every other "unexpected" expense you'll start feeling nickel and dimed by are shared by all older campers. New tires, battery, front rock guard lifts, re-sealing roof vents - possibly adding powered fan to main vent, re-sealing windows, switch out those incandescents for LEDs!
Otherwise, just make sure it all works. Appliances are expensive. You'll quickly double the price of your trailer. Furnace = $500. Fridge = $6-800. Etc.
Fridge is a tough one cause you have to get out and use it under high temps for a few days to know if it's really working well. I'm dealing with that right now...
Old 06-18-2016, 09:52 AM   #15
good points Zacho....
my beef with the stock furnace is the noise...the power it consumes(fan) and the fact that it is inefficient (all that heat coming out of the exhaust)...but that furnace is standard equipment in a whole lot of RVs...it's like the RV world is stuck in a time warp!!! there are a couple of new developments but the manufacturers still stick with the old technology....
having come to RVing from boats....I have a different perspective....like if my furnace "died"..or if I was building an RV from scratch I'd install a small propane fireplace with outside air intake for combustion...used EXTENSIVELY in sailboats that have a similar interior volume as our trailers......finding a place to put it in an existing trailer would be the challenge...but not insurmountable...(where I live/travel it would be worth it)
again from boats....I still have an oil lamp that I use in the trailer on cool nights...on my boats it did a great job of drying the air...while producing a smallish amount of heat and moving the air around...all night long....
expensive for a lamp....but as the manufacturer says: "Expect a LIFETIME of lighting pleasure from our lamps..." I've had mine for 20+ years and it still performs beautifully...
Old 06-18-2016, 10:33 AM   #16
ZachO's Avatar
Trailer: Sasquatch
Montana
Oh yeah. My post was not at all meant to be a "rebuttal" or anything to yours. RV furnaces are super inefficient and have a LOT of room for improvement. The fan definitely sucks a lot of battery power, and is loud. And if your battery is low, you've got no heat.
But as RV furnaces go, the one in the Bigfoot is sufficient.
Old 06-23-2016, 07:45 PM   #17
Trailer: 1975 boler
Say you bought a Bigfoot with minor to no problems ....what if Anything you guys would upgrade or do right away? Or for peace of mind ?
Old 06-23-2016, 09:23 PM   #18
Well of course first you want to make sure that the tires, brakes, bearings, frame, propane lines, etc. have all been checked and found to be in good working order. Those are your "peace of mind" items. You may have to replace the battery. Ours was shot.
As for upgrades, I can tell you some of the things we did: Switched all the running lights to LEDs and resealed them. Upgraded all the interior lights to LEDs too. Installed a combination propane/CO monitor and a new smoke detector. Added a larger skylight/vent with a Fantastic fan to the bathroom. Put in a new skylight/vent/fan in the main cabin area too. Got ourselves a free standing 100W solar panel. Added a small inverter. We ended up having to put in a new power center too. I think it's a smart idea to go ahead and just do that.
We had some rot in the door frame too. My husband removed the door, took it apart and rebuilt the frame. Fits better now too. Shortly after we bought our trailer the hot water heater died. We bought a new one and to save money we opted for the model in which you have to go outside and light a pilot light. Oh how I wish we had upgraded to a fancier one where you can just push a button from inside the trailer to light the hot water heater!
Hope this helps.
Old 06-23-2016, 10:00 PM   #19
Evergirl...quit your fretting....
.....hot water woes? just do like me...when I get to where I'm going...just after I do all the usual chores (block wheels, deploy awning, etc) I walk over to the water heater and start/fire it up...my experience with the heater is... a) it is VERY well insulated and it won't cycle unless you use water out of it....b) the pilot light uses a MINUTE amount of propane.......SOooooo...fire it up when convenient and leave it on....I would bet "dollars to dounghnuts" that whatever money you spend on extra propane to burn that tiny pilot light will be far LESS over time than the extra money you now wished you would have spent on that DSI unit .....JMO of course
now, I concur about the Power Center being at the top of the list of things that could use improvement...either it's blown and you need to do something about it...or it's about to turn your brand new battery into a boat anchor....sooner or later you will spend some money on that component....there are at least three different options....buy a new converter/charger "cartridge" that fits right in to the bottom of the old PC...buy a new, smaller, better PC now available....drop the converter/charger altogether and go to power from battery/ies all the time with a stand alone charger
people looking at BF 17s for the first time should realize that this trailer has two possible beds that are 41 inches wide...that width does not work for some couples (I'd say most but that's just me) and there have been lots of mods from owners to address/mitigate that perceived shortfall
happy shopping
bigfoot
Hi, New member TerryJan Info making Larger bed in 17ft Bigfoot terryjan Modifications, Alterations and Updates 13 04-11-2021 06:50 AM
Comparing 17ft Bigfoot to 17ft Casita LD Swasson General Chat 41 03-20-2013 11:00 PM
Need Info about Buying a 15-17ft trailer Margaret C General Chat 14 06-02-2009 07:18 AM
SOLD - Bigfoot 1990 17ft David H. Holsinger Classified Archives 8 04-10-2007 09:43 AM
1989 Bigfoot 17ft owners manual Yves Pelchat Problem Solving | Owners Helping Owners 3 11-20-2005 01:56 PM
