$1800 Ford F150 Tune-up - Page 2 - Fiberglass RV
Old 07-25-2009, 11:08 AM   #15
IllAnnoy
Thanks for the clarification Floyd. Do you know why the coil over boots are also recommended changing?
With 100000 miles between plug changes, it is probably wise . If not dried out or cracked at 100k surely would be before the second change.Failed boots could cause a misfire or damaged coil, so it's "preventative maintenance".
I tuned my ranger up at 100,000 miles and changed the serpentine belt, tensioner pulley,idler pulley, spark plugs and wires, replaced the front brakes, cleaned the fuel injection, replaced the manual trans fluid and differential fluid, as well as fuel and air filters. None of the above showed real signs of wear, but that's why it's called "preventative" or "scheduled" maintenance.
I will do it all again every 100,000 miles.Next time it will need rear brakes too, with oil changes, filter changes, and fuel injection cleaning more often of course.
With the exception of Tires, I consider maintenance other than that mentioned above to be "unscheduled".
I would say that waxing the thing every 3 mos is scheduled maintenance, but I'm just too lazy!
[Although, waxing may be as important as anything else.]
Old 07-25-2009, 01:44 PM   #16
pjanits's Avatar
Trailer: 17 ft 1986 Burro
I can believe it. After having 4k worth of rebuilt tranny put in my Jeep at 71k miles.. nothing surprises me.
I was freaked out that maybe I did it by towing, even if I am well below my rated limit.. Jeep said "No, you didn't cause this, sometimes, these things just fail. I have seen them go at 3k miles."
Does not bode well for their product, does it?
Chrysler has a long, long,long history of crappy transmissions that they refuse to admit are design deficient.
That may be why they are in the position they are today.
1972 Compact JR $1800 Robin G Referrals: Molded Fiberglass Trailers 1 02-07-2010 07:42 AM
1971 Havasu $1800 Robin G Classified Archives 2 12-13-2009 05:53 PM
FOUND - Seattle area (OR, ID, B.C.) - looking for an egg < 1800 lbs Andrea345 Wanted: Molded Fiberglass Travel Trailers 13 04-18-2008 07:29 PM
article: Ford preparing 60mpg F150 Frank G. General Chat 3 03-19-2007 09:56 PM
Trailer Tune-Up Guide Norman General Chat 0 08-18-2006 05:52 PM
