85 Octane Gas in Mountain States - Page 2 - Fiberglass RV
Old 06-28-2015, 10:14 AM   #15
When using radial engines it's engine cooling flaps than can be adjusted by the Flight engineer to control temp that is the equal of as thermostat. In as much as the temp of each individual cylinder can be monitored it's easier to spot overtemp problems. Our most common problem was from Gooney Birds going through the prop and blocking airflow between two or more cylinders. Other than that, the 3350-42 series was fairly cooling problem free.
ALL internal combustion engines are, basically, air-cooled. It's just that our engines use a liquid coolant as an interface between the generated heat of the engine and dissipating that heat into the air with a radiator. Ditto for oil and oil coolers, it's all about air.
We were towing all over the Colorado Plateau this past month, even with outside temps well into the very high 90's, were never for more than 10 degrees over normal temp, but we did see any number of late model vehicles pulled over from overheating, most often, IMHO, from not heeding the need to monitor speed and temps when driving.
On the leg between Prescott and Quartzsite, AZ, with temps over 115 degrees we didn't get more than 15 degrees over normal on the longest grades, but obviously many others did...
BTW: I drive 55...
Old 06-28-2015, 10:23 AM   #16
minke's Avatar
Trailer: looking
Originally Posted by Bob Miller View Post
ALL engines are air-cooled. It's just that our engines use a liquid coolant as an interface between the generated heat of the engine and dissipating that heat into the air with a radiator. Ditto for oil and oil coolers, it's all about air.
Acknowledged,,, but to be petty my sailboat's 10 HP diesel is indeed water cooled. Yes, the ocean may be air cooled, but perhaps the atmosphere is ocean cooled or even space cooled. Perhaps I get carried away too easily!!
minke is offline   Reply With Quote
For Sale: '72 Avocado Gas Stove and Gas/Elec Referidgerator havasu Parts: Buy | Sell | Trade 4 05-24-2012 10:19 PM
Just gas or gas/electric water heater? Feedback wanted. Bryan L. Care and Feeding of Molded Fiberglass Trailers 15 09-15-2010 09:11 AM
9 states, 5000 miles, 13' burro Jim Hovind Camping, Campout Reports 8 03-07-2007 09:45 PM
9 States using RV-Friendly Signs! Donna D. Camping, Campout Reports 2 02-18-2007 10:41 AM
