A newbie's lists! For camping and for troubleshooting. - Fiberglass RV
Old 03-08-2013, 04:03 PM   #1
Trailer: 1985 Burro 13'
We are going to look at a Burro tomorrow - woohoo! It's several hours away, though, and since I am the queen of "what if," I think, "What if (fill in the blank) happens between where it is at and home." Is there a list of things we should bring with us for on the fly repairs? I'm assuming you probably carry a small tool kit when you have the trailer - anything important that, as newbies, we might overlook?
I'm also curious what all you keep in your trailer on a fairly permanent basis and what you pack each time, or things that you've thought are handy to bring that I probably wouldn't think of bringing when you go camping.
Thanks!
just mary is offline   Reply With Quote
Old 03-08-2013, 05:11 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'd take a portable air compressor and a set of towing lights. There is a good chance the lights won't work properly. Also the tires may be old and rotten. You should also check the wheel hub temperature with your hand every 25 miles or so. It should be the same on both sides and not burn you. Also bring a jack and a lug wrench.
12 Volt, 100 PSI High Volume Air Compressor
Tow Lights - Save on this 12V Magnetic Towing Light Kit
Old 03-08-2013, 05:27 PM   #3
If I were taking a several hour trip that may result in towing home a trailer, I would be sure I had the correct size hitch ball to start out with, or I could take a couple with me as I have several. Next concern would be do the lights work, so I would take everything imaginable to check and repair if necessary, test light, wire, wire connectors, wire ties, bulbs, spare plug that matches what is on my tow vehicle, spare fuses that fit the tow vehicle, and some tail lights that I could clamp on if necessary. Problem here may be availability of these items, I have them all but most people probably do not. Tires could be a concern, so I would take a jack and tools to change a tire, couple blocks of wood, 2 X 6 & 4 X 4,. A 12 volt air compressor could come in handy. How about a license plate to put on it, hope this doesn't start a big controversy, but are you better off to tow it with no plate, or one from another trailer. I refuse to say what I would do. And in a worse case option, do you have a big enough tow vehicle to tow a rental car hauler trailer [Uhaul] with the Burro on it. When we bought our vintage teardrop 5 years ago it didn't look roadworthy so I brought it home in a Ryder truck, but I worked for Ryder so getting a truck and ramps was no problem. Our Uhaul was bought 20 miles from home so I had no concerns moving it that far. If you have AAA, they have a RV option that is around $20 extra on your policy, at least that is what I paid. Good luck, hope it's a good trailer and worth the trip, be sure to let us all know how you make out. Oh, bungees may come in handy too. Hopefully you won't need any of this stuff. edit, Tom replied while I was typing, I'm real slow at that! Edit again, Mary says take money, cash works good in negotiations!
Old 03-08-2013, 05:41 PM   #4
A new to you trailer wont have a spare tire jack or lug wrench. For your first tow remove the trailer hub caps and drive for 20 minutes. Then stop and grab the trailers axle hub to see how warm it is. If you cant comfortably keep yor hand wrapped around the hub because its too hot you need to stop and repack the wheel bearings. To do otherwise is to risk wheel failure on the road. These trailers sit a long time and maintanance is usually neglected. I believe in bringing some form of compressed air and a tire guage with you. It seems like the tires are always low or flat when you go to look at a trailer. A Bicycle pump is better than nothing and can get you to a place for more air. Check your spare before you hit the road. If you have Auto Club towing service call them now to add RV coverage so your covered if there is a miss hap. Call the seller and find out what size trailer ball you need and what is the hitch heigth. You cant tow it if your hitch doesn't match up. You might have to adjust your equipment once you decide that you want the trailer. The only real other issue is can you hook up the lights and make them work. Every used trailer I have ever bought had trailer light issues. everything from a different plug, to too short a plug pigtail, to just a bad bulb. I carry my own wire set just in case with 2 lights that I can C-clamp to the bumper just in case I cant get the lights to work. The older and cheaper the trailer the more these issues can creep up. See the trailer early, it easier to fix things in the morning than at 6:00 pm on a sunday night on the way home. Check the web before you go and see if there are any trailer supplies outlets in route just in case of trouble its nice to know where to go if you get stuck along the way.
Old 03-08-2013, 06:47 PM   #5
Thanks!
Welcome to the forum! You will find below links to a number of old threads on the topic of what people pack in their trailers and what stays in it all the time. I keep everything but my clothing and perishable foods in the trailer all the time. So all I need to do is throw some clothing in it and I am good to go once I stop at the grocery store on my way out of town.
What do you always keep in Your Egg?
Stocking Your First Trailer
Pack Mule
Putting together A Tool Kit
Old 03-08-2013, 07:54 PM   #6
A wheel bearing failure can cause a fried axle. Fifty cents worth of grease and 20-30 minutes of your time can save you hundreds of dollars.
Be safe. Best of luck!!
Old 03-08-2013, 08:09 PM   #7
Pam Garlow's Avatar
Trailer: U-Haul 1985
I'm glad that my UHaul has sealed hubs! I have my tire place check them periodically and so far so good. Welcome to the group, and please post photos of the Burro if you get it!
Old 03-08-2013, 08:43 PM   #8
The failures that have cost me the most money are "sealed and life-time lubricated".
Who's lifetime?
Old 03-08-2013, 09:35 PM   #9
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
What she said. A jack, a big pair of channel locks (normally I would shudder at this mention, but it's the best for this type of impromptu service, a couple cans of brake clean, two cotter pins, a roll of shop towels, and some grease (normally I would say dust seals, but if you're careful, you can make the old ones last to get you home).
I don't take the tire off the drum to service the bearings, just takes extra time. Just jack it up, pull the dust cap, pull the cotter pin, pull the axle nut, and slide the whole thing off as an assembly.
Who's lifetime?
x2, there is no such thing. Give me a grease zerk, etc., any day.
Odds are, you wouldn't have trouble without doing it, but consider the other option. If you weld a bearing to a spindle, now you're sitting alongside the highway, needing a new non-standard axle to put under your camper, which is probably welded in. It's that or a long-distance flatbed tow.
At the very least, I would pull the dust caps and check. If it was suspicious, I would be greasing them. Even if you had to putter to an auto shop and pay them to do it, it would still be cheaper than the possible failure, IMHO.
Greased bearings and a set of emergency lights as mentioned above will take care of 99% of the problems you will have.
Old 03-08-2013, 09:56 PM   #10
Bungee cords of different sizes - they come in handy to secure all sorts of things - even keeping doors that will not stay shut closed - dont laugh that has happen to a lot of folks picking up trailers for the first time.
Old 03-08-2013, 10:09 PM   #11
You guys are great, thank you! We know the bearings need greased, so if we get the trailer, we will do that before we leave the area. I will keep you posted!
Old 03-09-2013, 06:14 AM   #12
WHEW. Good to hear and very smart IMHO
BEST of luck and safe travels.
Old 03-09-2013, 07:19 AM   #13
Thomas G.'s Avatar
Who's lifetime?
I agree with this sentiment in general, but the UHaul sealed units are really bullet proof. They are automotive grade, same as 2000's Camaro / Firebird front wheel bearings. They are also used on rental car-dolly wheels.
Old 03-09-2013, 07:44 AM   #14
Originally Posted by Thomas G. View Post
I agree with this sentiment in general, but the UHaul sealed units are really bullet proof. They are automotive grade, same as 2000's Camaro / Firebird front wheel bearings. They are also used on rental car dolly wheels.
I'll agree and disagree both. I believe someone here had a Uhaul bearing fail, was it Cindy & Kevin maybe. Some heavy duty trucks, Freightliner for one, have used sealed bearings on the front axle [steer axle]. I have only seen one go bad, and it was hard to detect when it started to fail. The driver felt it when turning. When I jacked up the wheel and spun it I could barely detect a problem. We ended up with an elaborate device to check those bearings that involved attaching a magnetic strip to the wheel, a device to read it, and a crank handle that went on a lug bolt to spin the wheel. Never found another bad bearing. I carry a spare hub assembly when traveling, bolted into my spare tire.
Old 03-09-2013, 08:00 AM   #15
Pam Garlow's Avatar
Thanks for the great explanation, Tom. For all the campers that have bearings that can be repacked, I'm a believer in that maintenance. But for UH Peeps like me that are still running the sealed bearings,, I'll keep on just 'keepin on' with them. I don't want to have to change out hubs, rims, etc at this time. I camp locally rather than cross country. And Bob's idea about taking a UHaul rim assembly on long trips is a good one.
Can't wait to see if that new Burro follows someone home!
Old 03-09-2013, 08:14 AM   #16
Thomas G.'s Avatar
Originally Posted by Pam Garlow View Post
...... And Bob's idea about taking a UHaul rim assembly on long trips is a good one..........
You can just buy a hub at an auto parts store or on line and carry it for peace of mind. Mine came with a hub purchased in 1992 and it was still in the original box.
Old 03-09-2013, 04:04 PM   #17
We did end up getting the Burro! We drove it an hour back to where we are staying the weekend from where we picked it up. Pulled over halfway through and felt the hubs, they were cold. Still cold when we got back to where we are staying, so I was happy about that. The lights worked fine, my little Grand Vitara pulled it like a champ. We have about a six hour drive tomorrow, then we will get started on the fun stuff!
Old 03-09-2013, 04:07 PM   #18
Thomas G.'s Avatar
Congratulations. Aren't you glad that you were prepared?
Old 03-09-2013, 04:13 PM   #19
Definitely good to be prepared! The spare is worthless, so we want to stop pick up a new one before the trip home just in case.
Old 03-09-2013, 04:15 PM   #20
Thomas G.'s Avatar
Good plan. Tires over 5 years old can be ticking time bombs even though the tread looks great.
state lists or groups? john warren Forum Admin, News & Announcements 5 05-04-2012 12:08 PM
Hi, I'm definitely a newbie here and to this concept of camping Rvicsvol Hi, I am.... 30 05-03-2011 04:29 PM
Troubleshooting electric brakes Roy in TO Towing, Hitching, Axles and Running Gear 4 08-05-2009 06:34 AM
Numbered and Bulleted lists Mary F Forum Admin, News & Announcements 0 04-07-2006 11:34 AM
