Advice on which 13' - Page 2 - Fiberglass RV
Old 09-25-2010, 02:57 PM   #21
Marinab's Avatar
Trailer: 1977 TM14 Surfside / 2007 Toyota Tundra V8 2wd
I also think that many 14fter's in the used market might be getting over looked. Their are many of them that are just as wonderful as a 13fter.[/QUOTE]
As the owner of a 14 ft, I have to say that I love my trailer. That's just my opinion but I'm sticking to it.
Marinab is offline   Reply With Quote
Old 09-25-2010, 07:11 PM   #22
Trailer: 1983 13' Scamp
Massachusetts
Hi all, wow what great responses. Sorry about the delay, I did not expect so many fast responses. What I am hoping to find is a used 13' camper that is in pretty good condition. I am used to doing all the instalations and manitenance on our sailboat so fiberglass,electrical and plumbing is all ok. We are hoping to do a 3 month back packing trip to the National Parks next summer and having a camper would give us a great base. We also live on our sailboat so living in a camper would not be much of an issue for us.
These are the things we really want: cooktop, installed head (I could add this), 3 way fridge, 12v lights, light weight as the tow vehicle is a 4 cylinder truck
Nice to have:shower, hot water, heater
I am not sure if any but he newest trailers have showers, I see on the Casita website they have that option on the 13 now but I am not sure what year that started.
It would be great to be able to see some of these campers in person.
Thanks to everyone that has either emailed me or has responded. This stuff is very helpful.
Evergreen is offline   Reply With Quote
Old 09-25-2010, 07:26 PM   #23
Raya's Avatar
Hiya Evergreen,
To maybe figure out some limitations in order to focus our suggestions:
1) What is the tow capacity of your truck, what is the allowable tongue weight of it, at what point (if so) does it require trailer brakes, and are you required to subtract any of your truck payload from that total.
2) Older 13's with plumbed in heads and showers are rare, and typically a bit heavier, especially on the tongue (may not matter, depending on #1). As you say, you could add something.
3) 3-way fridges can be found in quite a few of the older 13s. This is a plus as they are rather expensive to buy new, and also there are no new ones made that fit under the typical 13-er kitchen counter (they are deeper now, so they project into the camper a few inches more than the counter, and you need to make a surround or etc.).
4) What is your budget? This may be something you don't want to share, but it would help us to make recommendations, rule out (or in) a new camper, etc.
5) Which Charlestown? (Aha, looked at your profile, must be Boston area.)
5) Your plan sounds great, by the way
Raya
Old 09-26-2010, 03:29 AM   #24
Massachusetts
HI Raya,
1. Tow capacity 3500lbs, tounge I think 350lbs. Not sure about the brakes and we need to subtract the payload. I know it will be tight.
4. Our budget is a little flexible, we just did not want to buy a new camper if it was not needed (actually our plan is a little more complex, after the 3 month trip in the camper we plan on taking our sailboat to the South Pacific so money is important).
5. Yes Charlestown MA is Boston. We are from Vermont though and spend a lot of time there.
Old 09-26-2010, 04:47 AM   #25
Raya's Avatar
Evergreen,
You shouldn't need to buy a new camper, as there are thousands of used 13-footers out there. And your tow capacity sounds fine. Even though most 13-ers are quite a bit heavier than the oft-touted 995#, it's not likely that you will top 3000# with any of them (although, as we always say, you have to weigh to know for sure, most 13-ers going down the road would proabably fall in the 1500# - 2500# range).
You may find that you need trailer brakes over 2000#, but those are addable if that is the case and the trailer you find does not have them.
One good thing is that there is an active market for these (as you will find out when you are looking for one), so if you wanted to sell again to top up the cruising kitty before heading across the Pacific, you would likely not have too much trouble. 13-ers especially, as they are the most flexible in towing requirements.
If you are not planning to drive a long distance to pick one up, then the brand may somewhat decide itself since there are not typically too many for sale in the NE (or in my area.... I drove ). But then you only need one
One thing you may re-consider is the plumbed in bathroom/shower. They are out there in the 13-ers, but much less common and also that takes away some from the open charm and simplicity of a small 13-er (that last is obviously just my opinion).
Most 13-ers, however, will have a niche for stowing a Porta Potti. WAG bags (which have changed their name to some clever pun now.... maybe it's Go Anywhere) are another option. Being on land opens up the options some as compared to being on the water (i.e. a lot more campgrounds and other stopping places have bathrooms/options than do anchorages!)
I don't mean to discourage you from finding a 13 with a bathroom, if you really want one; just sharing some of my thoughts.
Raya
(Also from snow country, originally)
Old 09-26-2010, 05:24 AM   #26
CindyL's Avatar
Trailer: 16 ft U-Haul VT
You can find a few ideas for adding a bathroom on this forum. Several people have done it. We did it to our 13' Burro when we had it, suspended shower curtains from pvc piping in the trailer and used one of the shower dodads that you can get at your camping store.
There are a couple of UHauls on ebay right now. They are both in the Midwest. The proprietary issue Raya brought up is there, but most of us have worked this out.
CindyL
Old 09-26-2010, 10:44 AM   #27
Byron Kinnaman's Avatar
Originally Posted by Donna D. View Post
Yeah Byron, Escape quit making the 13 foot blanks for TrilliumRV more than a year ago and stopped producing 13' all Escape trailers this past late spring/early summer
"At this time, we have decided to suspend production of the 13' Escape. With the introduction of the 15' and its competitive pricing, interest in the 13' has dropped off. Due to the demand, we are focusing on the units that are generating the most interest. Any 13' units currently on order will be built as scheduled." as found here: Escape Trailer Industries > Home
That means (I think) only Casita, Scamp, TrilliumRV (with a different vendor than Escape) and perhaps Team Trillium are building the 13 footers. Here's the Team Trillium (Outback) website: Trillium Trailers - Compact lightweight fiberglass OutBack travel trailers Calgary
Thanks for the update Donna D. I haven't been keeping up with Escape or Trillium these days.
Byron
Old 09-26-2010, 11:58 AM   #28
Raya's Avatar
Hi Cindy,
Just to be clear, I was not singling out U-haul or their proprietary parts as a "special" problem (and I was hoping that would show in the context of my earlier reply). I think they are nice trailers.
Quite a few people have added parts of bathrooms, and I'm sure that some have added (and some come with) "full" bathrooms, but that's getting to be a lot for a 13-er that someone is trying to keep reasonably light/simple (which maybe I'm reading into a little bit because as a sailor I like to keep things simple; and also considering the mission that Evergreen proposed).
The reason I say that is that, presuming somone is starting with a basic 13-er with the Porta Potti niche, well, then you are adding more water supply piping, grey water drain (and maybe holding tank) for the shower-drain water; black water tank for the toilet drain, and then perhaps more tankage (since a 10 +/- gallon supply is fairly meager for a "real" toilet and shower plus the kitchen sink.
Of course it's possible to rig up much simpler "showers," but I had got the idea from the earlier post(s) that Evergreen was wanting a real shower plus plumbed in toilet. I'll have to go back and confirm that.
At any rate, it's certainly doable. I was just chiming in with my thoughts and opinions considering things like finding a trailer in the NE, towing for a single three-month trip to the opposite coast (potentially with some weight limit if moving luggage/boat supplies and having to subtract cargo weight from towing cap + 4-cylinder + mountains), being on a budget, and then maybe (?) re-selling at the end of that time. Some of this I'm inferring from what we do know.
As is probably obvious - given the parameters we know - I would stick with the Porta-Potti/WAG bags,and Navy baths plus my garden sprayer shower, except when at campgrounds and able to use their showers. But part of the beauty of it is that we can all do our own thing. OTOH, since Evergreen asked for opinions, I figure seems okay to give them, too, as long as I'm not posing them as fact.
Raya
Old 09-26-2010, 04:52 PM   #29
CindyL's Avatar
Raya, I did not take it as a UHaul jab. It is an issue to consider. I was just adding that it can be worked around.
Someone did plumb a whole bathroom in the front of a UHaul. I think the description and pix are over on uhaulcamper.com.
CindyL
Old 09-26-2010, 06:04 PM   #30
Raya's Avatar
Okay, great Cindy, I just wasn't sure.
I looked at a Scamp 13 wherein the owners had removed the front bench, walled off that whole section, and installed a shower and a toilet. For myself, I couldn't see using 1/4 to 1/3 of the trailer for a room where I only spend ten minutes a day, but I know that for others it would be a huge plus. I missed the visual space, and the area by the door to set stuff down, etc. Also, on that particular camper it was done in plywood, and was a bit rough. I'm sure it could be done nicely.
Raya
Old 09-26-2010, 06:09 PM   #31
I agree with Raya, every inch put into a bathroom takes an inch from somewhere else. I'd rather have more storage or a bigger bed!
If looking to buy used, first (or second) concern has to be budget, then tow capacity (that could be first too!). There are many, many brands of 13 foot trailers that come up in the used market. Fewer available the larger the trailer. Then there's availability and how far one is willing to drive to view/buy. There are some that don't want to drive more than an hour or two, and that can be limiting. YMMV
Old 09-27-2010, 06:20 AM   #32
Massachusetts
Thanks for all the advice, we are going to be looking today at the Scamp 13' listed in VT. Hopefully it will be a good one. As with everything I am sure there will be a learning curve for us with this so our "needs" will probably change with a little experience.
Old 09-28-2010, 10:37 AM   #33
Massachusetts
Just wanted to thank everyone that responed to this thread. We agreed to buy Jessica's 13 foot Scamp that is listed in the for sale section. We needed to get a trailer hitch so we don't have it yet, hopefully this weekend.
Old 09-28-2010, 11:11 AM   #34
Massachusetts
One more question. If our real trailer hitch does not come in by this weekend would you all think it would be ok to just put a ball on our metal bumper? It has a hole for it. I would have to tow it for about 50 miles.
Old 09-29-2010, 08:32 PM   #35
I missed it, what is the tug? On the bumper, right by the hole for the hitch ball are some numbers for the hitch weight. DO NOT exceed that amount. The tongue weight for a 13' Scamp "should be" right around 100 lbs. It would okay to tow the trailer "slightly" tongue up for 50 miles or so. But, personally, I wouldn't care to do it much more than that and remember the fulcrum effect takes place and tongue up means more weight is now at the axle and back. Plus, you'd need to make certain you don't scrape bottom going in and out of driveways with the back of the trailer.
Congratulations by the way!!!
Old 09-29-2010, 09:07 PM   #36
floyd's Avatar
Our 13 deluxe front bath has both more storage space and a larger bed than a standard with front bunks, what we don't have is front bunks and room to sleep two more.
The only thing I miss at all is the ability to remove the curtains and see right through the trailer when towing, a clear atvantage to not having the bathroom.
Seeking your advice on a Scamp 13' purchase Bill caulway Problem Solving | Owners Helping Owners 7 08-06-2010 09:44 PM
Looking for 13' Scamp Bill caulway Classified Archives 2 08-02-2010 10:28 AM
Looking for a Scamp 13' Bill caulway Classified Archives 0 08-02-2010 08:44 AM
Small family in a 13'? Legacy Posts General Chat 11 06-07-2003 03:20 PM
Pictures of my 13' Scamp Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 02-18-2003 03:08 PM
