AGM in a Scamp - Fiberglass RV
Old 03-01-2018, 06:50 AM   #1
Idaho
AGM in a Scamp
Has any Scamp owner put an AGM battery in the inside back location just like the Casita owners have thereís? I would like to take the 60+lbs off the tongue. Wondering how hard it would be to relocate the wires. Thanks for any insight. Iíve also seen on YouTube a Scamp with 4 brake lights. Is this one of those unknown options? And why would you want 4? Also, the Scamp store offers alloy wheels for the Scamp. Is this also another unknown option?
Bill
Billpq is offline   Reply With Quote
Old 03-01-2018, 07:05 AM   #2
More brake lights = more visibility to other drivers, always a good thing! We have the upper brake light option on our Escape, night and day difference from the standard lights.
Another battery to consider if you are going to change is one of the lithium iron models. Yes, they are not cheap! But they are super light weight, no venting required, can be mounted in any orientation (on their sides, upside down, whatever). They claim a 10X lifespan, and you can use almost 100% of the battery's capacity, versus 50% of a traditional battery.
I am not endorsing these batteries. I would do a google search on them, as I see them discussed on many different RV forums. If it truly lasts 10 times as long, the price is actually very reasonable.
https://battlebornbatteries.com/?gcl...SAAEgIpbvD_BwE
thrifty bill is online now   Reply With Quote
Old 03-01-2018, 07:07 AM   #3
Scamp will install a second, high mounted set of taillights on the 16' and 19' models. Not sure whether it's on their current build sheet, and I have no idea why they won't do it on the 13' models. Three reasons: (1) if you carry bicycles, they often partially obscure the lower taillights, (2) in close traffic, a vehicle close behind you may not be able to see the lower set because they are so low, and (3) better general visibility at night.
First I've heard of alloy wheels through Scamp. I'm not seeing it on their website.
Old 03-01-2018, 07:12 AM   #4
I highly recommend the Scamp second set of tail lights or something similar. The stock ones are low (and not real bright) and can be hidden be a vehicle following you closely, or not seen by that driver at times. Higher lights are safer and are used on most other vehicles. Rear end collisions are the most common type of crash and higher tail / brake lights help to prevent them. The lights are $95 at build time but apparently not available on the 13 for no reason that I can fathom.
Old 03-01-2018, 07:30 AM   #5
Trailer: 2014 Escape 21, Lil Joe
Several years ago I collected info. on fiberglass trailer crashes. Scamp trailers are more prone to be rear ended than other fiberglass trailers. The pre 1996 or so with top hat tail lights are really dim and hard to see. A third higher LED brake light (owner installed) or dual brake lights (factory installed) is a good safety investment on a Scamp.
Eddie
Eddie Longest is online now   Reply With Quote
Old 03-01-2018, 07:45 AM   #6
Idaho
If this is such a safety issue, why donít they offer it on the 13í. Iíll have to call Scamp and find out why. This should not be an option, but included in all sales.
Old 03-01-2018, 08:22 AM   #7
Idaho
You can see two options for rims in this video, along with 4 tail lights.
https://youtu.be/s-qvd74DHn0
Old 03-01-2018, 08:35 AM   #8
Vermont
second set of lights
When we had our 13' built, we attempted to order the second set of lights. According to Scamp, the shape of the 13 footer does not allow proper placement of the lights and that is why that option is not offered.
Tony M is offline   Reply With Quote
Old 03-01-2018, 08:36 AM   #9
Trailer: Scamp 16, previously Scamp 13
None
My 1999 13foot has the extra set of tail lights. I bet they would put them on if you asked. Would be a potential deal killer for me if they wouldn't. One set of the standard, dim lights is inadequate in my opinion.
LyleB is offline   Reply With Quote
Old 03-01-2018, 08:37 AM   #10
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Bill
While the upper taillights make sense, I'd be concerned about the battery move. Even a light carrier on the back of a Scamp can lead to problems with sway due to low tongue weight. Moving that much weight from the front to the back may lead to stability problems.
Old 03-01-2018, 09:05 AM   #11
Yes perhaps the big square light fixtures don't fit so well...
See if you can get them to run the wiring and leave it behind the rat fur, under the rear window, like they do for the A/C pre-wire. That will make it easy for you to add some small LED lights on your own.
Old 03-01-2018, 11:55 AM   #12
Trailer: 13' Perris Pacer
Mount two of these inside your back window. Connect the wires to your turn signal/brake light/ground wires. Problem solved!
https://www.ebay.com/itm/Practical-2...JXhyPm&vxp=mtr
mchalewj is offline   Reply With Quote
Old 03-04-2018, 09:28 AM   #13
william looking
William thanks for the tip on the lights I think with our high mattress I can just hook the lines on the inside and go for it.
thanks
bob
Flooded Lead Acid vs Valve Regulated Lead Acid (AGM & Gel) The Minimalist Modifications, Alterations and Updates 6 08-24-2014 09:30 PM
Optima AGM batteries...Which one? Jim Sinor Electrical | Charging, Systems, Solar and Generators 20 05-21-2013 05:43 PM
Parkliner Electrical System & AGM Battery Charging-Maintaining accrete Electrical | Charging, Systems, Solar and Generators 15 05-16-2013 06:03 PM
AGM Battery ? jck Care and Feeding of Molded Fiberglass Trailers 29 12-28-2012 04:46 PM
Got a 2nd battery, AGM, 2 questions?! dylanear Modifications, Alterations and Updates 13 07-28-2012 02:47 PM
