Air Conditioning - Fiberglass RV
Old 04-28-2010, 10:36 PM   #1
Trailer: 1985 13 ft U-Haul
Well here we go with the perpetual pursuit of a solution for a/c in our little eggs. While surfing the web I went in search of portable refrigerated air conditioners. Most of the units seemed too large, too heavy etc. but one that I found seemed like it might work. That unit was the Koldfront PAC 8000s. The weight was 53 pounds dimensions H 24-3/4" W 19-1/4" D 13-1/2" (might fit in the lower area of the furnace compartment of our 13 foot Uhaul facing the front as we have removed the furnace ). The propaganda states that if will cool 225 square feet. The unit appears to exhaust the hot air through a 5" hose ( wouldn't require a hole in the side of the Uhaul much larger than the current furnace exhaust ). Does anyone have any experience with this unit or even this type of unit ? If this or something like it would work it could perhaps solve the problem of adding air to units which were not built to support the additional weight of an a/c on the roof ( which is actually probably most of our units ). The best news is that the cost is less than $300.00. Comments please. Lee
Lee Senn is offline   Reply With Quote
Old 04-28-2010, 11:11 PM   #2
Trailer: 2005 13 ft Trillium Outback
Koldfront info link
The smaller size is nice. Problem might be the single exhaust hose. The value or not of single versus dual hose A/C units have been discussed previously on the forum. My recollection is that a single hose unit winds up continually trying to cool the hot air drawn in to replace the partially cooled air it is using for exhaust. YMMV. I have an 8K dual hose and it would struggle in 105 degree Texas heat.
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Curtis F. is offline   Reply With Quote
Old 04-29-2010, 12:23 AM   #3
Roger C H's Avatar
Talking
IMHO I wonder when we place home appliances in our eggs if they can stand the beating they get from traveling. Aren't RV appliances built more robust in order to take the highway pounding?
Old 04-29-2010, 06:18 AM   #4
Joe Z's Avatar
Trailer: 16 ft Casita Spirit Deluxe
I had a 5000 btu house unit in my trailer since 1994 and it took no beating and still cooled good ..... the only reason i changed it for a new one was because the fan on low was starting to get noisy and it bothered us.
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 04-29-2010, 06:22 AM   #5
Trailer: 2009 17 ft Eggcamper / Chevy S-10
We used one of the portable air conditioners in the office where I used to work, and it didn't seem nearly as efficient at cooling as did a conventional house-type unit of equal BTUs.
Old 04-29-2010, 06:40 PM   #6
Koldfront info link
Curtis I did find some posts regarding single hose situations and one of the product reviews also mentioned their drawbacks. I am wondering if this couldn't be resolved by making a second small diameter, maybe say 5 inches , hole in the Uhaul body right next to the one made for the exhaust. Perhaps then the air drawn in thru the second hole would feed the air requirements without drawing the air required from inside the trailer and then the air inside the trailer would be recirculated, much as in an automobile. Neither my wife nor I tolerate heat well which is why we retired in reverse to the norm that is left the southwest and moved north to retire. Most of our camping is done in Idaho, Washington, Oregon and Montana and 90% in the mountains above 5000 feet. We are almost always in shady, heavily forested areas and temps above the low 90s would be seldom, if ever , encountered. Again thanks for the input of all. Lee
Air conditioning drews60 Problem Solving | Owners Helping Owners 14 06-12-2008 06:01 PM
Air Conditioning Parker Buckley Problem Solving | Owners Helping Owners 8 03-02-2008 03:22 PM
Add On Air Conditioning Idea Patrick M. General Chat 1 08-20-2006 11:38 AM
New Boler Air Conditioning Jollean Modifications, Alterations and Updates 6 01-15-2006 05:23 PM
AfterMarket Air Conditioning Pete Dumbleton General Chat 4 01-03-2006 12:05 AM
