04-08-2008, 08:05 PM
#21
Per's latest wiring:
04-08-2008, 08:15 PM
#22
That's because everything is remote controlled. Ya know the do-hicky that runs the A/C, that deploys the TV antenna and backup camera... that turns on the BATH TOWEL WARMER!!
04-08-2008, 08:28 PM
#23
Maureen: see what kind of surreal universe you have entered!
Roger used to have a 17' Burro. Sold it, and has been on a regret trip ever since. He does touch on one of the unique benefits of the double-hulled Burros: easy to wire.
And Roger: I am conscious of weight and always try to compensate when I add something. Why, the other day I removed some of the vinyl striping I had put on some time ago.
Actually everyone, I believe Maureen has likely gotten the message that her Burrito is somewhat of a bargain.
Sadly, Per is right! I really do miss the Burro...
Roger
04-08-2008, 08:31 PM
#24
04-08-2008, 11:26 PM
#25
Trailer: Burro 17 ft Widebody
Bogus. I never use those twisty-dohickeys. And especially not yellow ones.
I always weld the connections. Then wrap them in several layers of electrical tape, then heatshrink tubing.
Very heavy but reliable.
Donna, that is SO yesterday. Wait 'til I show you the latest remote-controlled fan. Touchscreen. Backlit.
Maureen, this is not something to be emulated.
04-09-2008, 11:58 AM
#26
Trailer: 1987 Burro 13 ft
Well, you all have quite the group here. I am quickly finding out.
I have a few more questions.
Are original parts available anywhere?
Are the trailers worth more original or modified? I have been pondering laminant floor.
I have noticed weakness in the floor right by the door, repair ideas? I have some angle iron and was thinking I could attach it to either side of the frame below the door, good idea or not?
Also the original water pump is gone and a faucet hooked to the city water feed, they have disconnected the water tank entirely. just left the lines so that is no biggy, simple enought to route so I may just go ahead and buy new water line.
I need to find a hand pump. New? or Should I search for original?
If I need to go to a different forum for these questions somebody redirect me.
04-09-2008, 12:14 PM
#27
Trailer: Bigfoot 25 ft / Dodge 3500HD 4X4 Jake Brake
Maureen,
We have a section a little higher up called:
"[b] Problem Solving -- Owners Helping Owners
Share your problems, concerns, fixes of Molded Fiberglass Trailers."
That would be a good place to ask your questions. If you ask one question at a time, New Topic for each, it makes searching later easier and the entire thread can stay on topic. Well we hope.
04-09-2008, 01:09 PM
#28
Per's wiring plan:
04-09-2008, 01:18 PM
#29
OK, Pete... quit funnin' us. I KNOW that's not Per's wiring. His is much better than that. Why... I don't see a single weld in that nest.
Roger
04-10-2008, 07:35 AM
#30
Trailer: Compact Jr
Cat heater: The heater is controlled by a circuit board at the bottom; you might try pulling and reconnecting the four electrical connectors at the lower left corner of the board. I suspect they get a bit of corrosion on them, and disconnecting/reconnecting them might help scrape some corrosion off the pins.
04-10-2008, 04:48 PM
#31
We're drowning in Central Iowa, Too wet and too cold to go out and play.
Bout ready to mount the Burro to my pontoon
04-10-2008, 05:42 PM
#32
Oh I get it now, this is the leak test for the burro.
Got a couple, 2 small drips by back window and one at the vent. I am already pondering a fantastic fan so I have to pull it anyhow.
I am thinking I should pull the inside trim from the back window and check the integrity of the seal from there? Any suggestions?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Maureen Spotted a Love Bug!
Maureen S |
Classified Archives |
5 |
11-19-2009 08:46 PM |
Maureen's questions
Per Walthinsen |
10 |
04-11-2008 04:49 PM |
Introduction
Doug Herr |
General Chat |
6 |
07-16-2007 09:44 PM |
Introduction
Dave Eizinger |
General Chat |
5 |
07-12-2007 08:20 AM |
