Another clueless question... - Fiberglass RV
Old 05-24-2008, 12:03 AM   #1
Trailer: 13 ft Scamp
Do the scamp trailers only have water tanks/jugs or can they be hooked up to rv water hookups?
you guys are the best!
Lynn L is offline   Reply With Quote
Old 05-24-2008, 12:33 AM   #2
Greg A's Avatar
Trailer: 2015 Escape 19
Lynn,
There should be a city water hookup on the same side as your electrical. You'll need a new potable water hose you can get at Wally on the RV aisle. I wouldn't use the onboard system as long as this one has sat without either replacing or thoroughly sanitizing with bleach.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 05-24-2008, 12:37 AM   #3
Oh yeh, and would the scamp be a 30 amp hookup or???
sheesh!
Old 05-24-2008, 04:09 AM   #4
kconley's Avatar
Trailer: 95 Casita Spirit Deluxe 16 ft
sheesh!
Yes indeed it is a 30 amp hook-up 110 volt...................
kconley is offline   Reply With Quote
Old 05-24-2008, 06:26 AM   #5
Buy a couple of jugs of water. You don't want to get sick on the trip home. You can refill the jugs at the campground for washing dishes, potty stuff, etc. Any water that goes into your mouth or is used for cooking should be fresh, clean water.
Old 05-24-2008, 07:37 AM   #6
Trailer: Scamp 13 ft
30 amps???????? It depends on the year of the Scamp. My '83 is only 15 amp electrical service (in which a 15 amp to 30 amp plug comes in handy for when just a regular plug is not available). Should be a sticker by the cord that states its amperage.
Chris L. is offline   Reply With Quote
Old 05-25-2008, 04:43 PM   #7
Pete Dumbleton's Avatar
I think Scamp standardized on a 30A/120VAC shore cable in the '90s. That way one electrical setup fit all options. I removed mine and replaced it with a 15A/120VAC cable for less weight (and my BulgeMobile friend appreciated the opportunity to make a 30A/120VAC extension cable).
Adapters to hook to 15A/120VAC and 50A/240VAC might be needed, depending on the kinds of campgrounds one uses.
help! clueless about dumping gray and black water tanks joy mccalla Care and Feeding of Molded Fiberglass Trailers 12 04-18-2010 08:13 PM
Question Rob M Forum Admin, News & Announcements 3 10-26-2009 08:51 PM
Clueless about my new Scamp! Lynn L General Chat 20 05-25-2008 01:15 AM
Cat Question Ian-Vicki Problem Solving | Owners Helping Owners 13 08-20-2007 10:03 AM
Answer a Question then Ask a Question CarolnJim General Chat 77 06-03-2006 11:39 AM
