any guesses? - Fiberglass RV
View Poll Results: Temperature rise from almost freezing
15 mins 6 14.29%
1/2 hour 14 33.33%
45 mins 13 30.95%
1 hour 4 9.52%
2 hours 2 4.76%
4 hours 1 2.38%
somewhere in between 1 and 4 hours (Chicken&#33 1 2.38%
You're gonna die of hypothermia waiting 1 2.38%
Voters: 42. You may not vote on this poll
Old 01-19-2008, 12:52 PM   #1
Gina D.'s Avatar
West Coast USA
HONEST people can vote first, THEN read the answer :-P
I just went up to my trailer to turn the furnace on so I can do some prep work on it for an upcoming trip.
The thermo said it was 34 degrees at time of turn on. (No water in the tanks.. it's OK)
The time I did this was 11:30
How long do you think before the temp goes up to 70? (Thermo setting cut off)
I am guessing an hour, but..
might be fun to see. I will check the temp once every 15 mins.
It's a 17 foot insulated Burro. All vents and windows closed.
So..
cold start:
34 degrees at 0 hours.
Old 01-19-2008, 12:55 PM   #2
Gina D.'s Avatar
West Coast USA
guesses....
Old 01-19-2008, 01:01 PM   #3
Gina D.'s Avatar
West Coast USA
11: 45 ~ 41 degrees
12 noon ~ 52 degrees
Old 01-19-2008, 01:09 PM   #4
Chester Taje's Avatar
Gina-----It all depends on outside temp.
Old 01-19-2008, 01:14 PM   #5
Gina D.'s Avatar
West Coast USA
The weather underground station just a block up the street says it's currently 41 degrees, no wind (*F* for our Canadian friends)
It's too cold for me to be out there. I am a whimp
Old 01-19-2008, 01:24 PM   #6
Gina D.'s Avatar
West Coast USA
12:15 ~ 60 degrees.
Old 01-19-2008, 01:37 PM   #7
Gina D.'s Avatar
West Coast USA
12:30 ~ 65 degrees.
I am not a physisistststst. I can't even spell it, but it's interesting to see it stall as it gets closer to temp. Maybe I should have paid more attention in science class.
Outside temp = 42 degrees
Old 01-19-2008, 02:03 PM   #8
Spelling class too
Old 01-19-2008, 02:13 PM   #9
Gina D.'s Avatar
West Coast USA
yeterai, I coont spell it, toodai, I are won.
12:45 ~ 68 degrees
1 pm ~ 69 degrees.
Furnace still going when I exited at 1:05.
I have to leave it running.. I have some wet cushions! I haven't been in it for any period of time since thanksgiving, so didn't notice.
I think it is just pooled condensation as the moisture is limited to things well below the windows (Curtains are fine and show no signs of staining) and there are some drips pooled on top of the cloth shower curtains I have as covers.
They appear to work, the tops of the cushions are bone dry and the only wet parts are where the shower curtains didn't cover.. on the bottom between the top of the bench and the cushion bottom.
All the cubbies are dry.
Old 01-19-2008, 02:44 PM   #10
Gina D.'s Avatar
West Coast USA
1:30, still 69 degrees
1:35, 70 degrees and the furnace kicked off, for about 2 mins..
outside temp still 42
so, I guess 2 hours and 5 mins is the answer.
Old 01-19-2008, 03:06 PM   #11
Gina D.'s Avatar
West Coast USA
Can a scientifically qualified person explain the stall?
Is it because it reached a point where it is losing heat around the thermostat at about the same speed it is replenishing it?
Ches' point about outside temp was a good one, and it just so happened it remained pretty much the same throughout the experiment, adding control and bumping that out as a contributer.
Old 01-19-2008, 03:36 PM   #12
Mike Taylor's Avatar
Trailer: Hunter Compact II
It's the same theory that a watched pot of water will take longer to boil water. If you go into the other room for a little internet the next thing you find is an empty pan with mineral deposits.
Mike Taylor is offline   Reply With Quote
Old 01-19-2008, 04:50 PM   #13
Trailer: Fiber Stream
Talking
70<sup>o</sup>F? Mom says, "Put on a Sweater!"
Old 01-19-2008, 04:58 PM   #14
Gina D.'s Avatar
West Coast USA
Mom doesn't live in my trailer. I can eat popcorn for dinner too
OK, who is cheating?
Voting after the answer is given... sheez, you guys are incorrigible!
