axle - Fiberglass RV
Old 02-06-2013, 01:51 PM   #1
vics454's Avatar
Trailer: 1973 Boler
axle
I am looking for an axle for my 73 Boler. If I could fine one in Alberta, that would be best. I would like to get started on the upgrades for the summer.
Vic.
vics454 is offline   Reply With Quote
Old 02-06-2013, 03:56 PM   #2
FTTRV's Avatar
Trailer: tp
You should find a new axle at a RV dealer in your area. You need to measure center of tire to center of tire to get the correct length.
Chuck
Old 02-06-2013, 04:41 PM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Check these guys out:
Dexter Axle - Trailer Axles and Running Gear Components - Canada
Old 02-06-2013, 04:52 PM   #4
David Tilston's Avatar
They may not be the least expensive, but Standen's does good work, and they are in Calgary.
Standen's Limited :: Leaf Springs, Trailer Axles, Stabilizer Bars, Suspension Hardware, and Tillage Tools
Old 02-06-2013, 10:44 PM   #5
Brian B-P's Avatar
That will get you the track dimension; it is probably intended to yield the width across the hub faces, and based on the assumption that trailer wheels all have zero offset (the face against the hub is in the middle of the wheel's width). In reality, Dexter Axle no longer sells wheels (they sold the product line, perhaps now sold as Dexstar), but when they did they apparently had 1/2" offset; the conventional style of Dexstar wheel still has 1/2" offset in most sizes. My 1979 Boler has 1/2" offset wheels, as most likely did from the factory. If the wheels have 1/2" offset, measuring the track and calling it the hub face width will result in an axle 1" too narrow for the wheels.
Far more importantly, the hub face width is only one of several bits of information needed to specify a rubber-sprung "torsion" axle. Some of the others:
  • bracket spacing (to match frame)
  • bracket orientation (again to match frame design, and coordinate with spacing dimension)
  • capacity (if a Dexter then the Torflex product series, such as "#8" or "#9", plus rubber adjustment if not specifying full axle series capacity)
  • arm starting angle
  • spindle length (regular or extended)
  • brakes, brake flanges only, or no brake provisions
  • hub bolt pattern
Standen's is quite capable (although no one is perfect), and is the original supplier of axles for Bolers manufactured in Calgary and Winfield circa 1979. In case you're not in Calgary (it's not the only city in Alberta)... Standen's has other locations, including in Edmonton.
Old 02-06-2013, 11:24 PM   #6
Thank-you Brian! I have wondered about this very subject. I had my axle changed, and did not know enough to even ask about this.
As I am very visual in my understanding of things, do you have access to a drawing that shows where these values are measured from?
Old 02-07-2013, 07:59 AM   #7
Ian G.'s Avatar
I had Standen's build my axle and they did a great job.
One other item to consider is that the 13' Boler body is offset on the frame by 1" to the left or drivers side. If you have the axle mounting bracket welded to the axle with this offset as a consideration the axle and wheels will be centered under the body of the trailer rather than centered under the frame.
To view the offset on your trailer just look at the tire sidewall clearance to the side of the body, you will see that one side is very close to the body and the other side has extra clearance.
Take careful measurements as each frame will be a bit different.
Old 02-07-2013, 08:45 AM   #8
Brian B-P's Avatar
I went straight to the authority on Dexter axles (Dexter Axle), picked "Resource Library" from their menu bar, and Axle Measurement from the "Trailer Axle Resources" drop-down list. The result is really densely packed, but very informative and entirely pictorial - I like it. They have other literature with extensive explanations of how to choose and install their axles... that's just the most succinct and graphic bit.
Most axle distributors seem to have an order sheet showing an axle with the required dimensions labelled, but maybe not for torsion axle systems.
Roy in TO posted a thorough thread describing his Boler axle replacement (everything Roy does is thorough ), complete with illustrations: Replacing an Axle - leading arm to trailing arm. He did change the axle configuration substantially, which might be confusing for someone wanting a direct replacement, but he includes a dimensioned drawing showing the axle in the context of the trailer body and frame, as well as a drawing from Redneck Trailer. I didn't see the Redneck drawing on their site, but the axle section of the Redneck catalog) has information about ordering Torflex axles, which all looks like it came out of Dexter documents.
Old 02-07-2013, 09:13 AM   #9
Ian G.'s Avatar
Originally Posted by Brian B-P View Post
Roy in TO posted a thorough thread describing his Boler axle replacement (everything Roy does is thorough ), complete with illustrations: Replacing an Axle - leading arm to trailing arm. He did change the axle configuration substantially, ...
Yes Roy's documentation is thorough, my reference is simply information that the offset exists and can be applied when replacing the axle in the standard leading arm configuration.
Not everyone wants to tackle the complexity in changing the axle configuration to a trailing arm. Those of us who have done it are aware of this and Roy has documented his conversion in detail. In my mind if anyone is going to the expense and work of replacing the axle, even when leaving it in the standard leading arm configuration, why not have the brackets welded on the axle to take the offset into consideration.
Old 02-07-2013, 10:24 AM   #10
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Make sure you get your custom wheels first! Put them on your present axle to ensure the present axle width will work.
But hey your no dummy, you knew that!lol
Fred
FRED SMAILES is offline   Reply With Quote
Old 02-08-2013, 08:46 AM   #11
Brian B-P's Avatar
I started my reply before Ian posted his, so I didn't see his post.
Excellent point - I agree. I completely missed that feature in my list of potential specs... which was the theme: there's a lot more here than hub face width.
For another example, the Dexter graphic which I linked explains the two heights of bracket, and the option of side-mount (bolt-on) brackets, each of which leads to another decision.
axle
« Chairs again | Snow »
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
need a new new axle? Perry J Problem Solving | Owners Helping Owners 1 09-29-2012 06:09 AM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
