Back from Lil Snoozy with Eye Candy!! - Page 9 - Fiberglass RV
Closed Thread
Old 04-03-2011, 05:42 AM   #113
Here's all the shuttle names from the TNG Star Trek series, I scooped from here: http://startrekman.webs.com/tngshuttlecrafts.htm
Argo
Campbell
Chaffee-Defiant
Cochrane
Copernicus
Cousteau
Curie
D'Alison
Dawkins
Delta Flyer
Delta Flyer II
Drake
El-Baz
Fermi
Feynman
Galileo
Goddard
Harris
Hawking
Hawking
Justman
Kotoi
Ley
Magellan
Onizuka7
Pike
Sacajawea
Sakharov
Tereshkova
Verne
Voltaire
Cassette Toilet? Maybe this will help:
Donna D. is online now
Old 04-03-2011, 06:40 AM   #114
Trailer: 2002 Casita 17 Spirit Deluxe
Thanks for the video. Different strokes for different folks. Looks like a blue tote without wheels to me. I would much rather disconnect and drive to dump station if needed, than deal with carrying and dumping that tank by hand every few days.
Jerry Chapman is offline
Old 04-03-2011, 08:04 AM   #115
CallDon's Avatar
Trailer: Still deciding, but changing my mind from the Casita FD to the Lil Snoozy!
Originally Posted by Mike Magee View Post
CallDon, I hear you, I keep trying to figure out a way to fit a LaZBoy into my trailer also.
The Casita Freedom Deluxe has the two captains chairs. When removed, there might be enough room for a smaller recliner. You could push it against the wall for traveling and when you need to cook or use the kitchen. Then move it away from the wall so you could stretch out and watch TV. It would be great for one person...or two, if the other person sat at the dinette/bed in the back.
i still need to investigate and do some more measuring. The smaller footprint of the special RV recliners might work if you can get them through the door!
Don
CallDon is offline
Old 04-03-2011, 08:13 AM   #116
David and Nancy's Avatar
Trailer: Bigfoot 25 ft (25B25RQ)
Donna - the YouTube link was exactly right for clarifying the cassette toilet.
We rented a class C motorhome for three weeks in New Zealand a few years back. That rig had a cassette toilet exactly as pictured in the video. It was extremely easy to use and I think it is excellent technology. The tank is about as large as any small black tank installed in a conventional FGRV so you wouldn't have to empty it any more often. Having a cassette really increases the options of places to dump and it is so easy to give it a good cleaning after you get home. Since we often stay at Forest Service and Park Service campgrounds without hookups, the ability to haul the cassette to the dump station would be a real plus. We currently have a Thetford tote for that, but it takes up a lot of cargo space and using it requires dumping the same load twice.
I think the Lil Snoozy is a great-looking design and using the cassette is one more example of innovative thinking. I want one!
David and Nancy is offline
Old 04-03-2011, 08:21 AM   #117
Trailer: 1980 Burro
2) Will the shape effect the tongue weight. Since it is shaped like a wing, will the air flow push up or down?
Raz
The front shape looks like it could cause instability when towing at speed with half the airflow going over the top and half under the bottom. It the trailer was towed out of level with the hitch ball either higher or lower, that could significantly affect the weight on the hitch ball due to aerodynamics. The effect would become stronger as speed increases. Also, different sizes and shapes of tow vehicle may have an effect on the amount of air going over vs under the trailer. Hopefully they have done a lot of road testing at high speed to make sure there are no negative aerodynamic effects.
Andy B is offline
Old 04-03-2011, 08:31 AM   #118
Trailer: 1984 Scamp 13'
Maryland
That's a great-looking camper! I wish you the best, and can't wait to hear more about it. The price seems too good to be true when compared with Scamp and Casita. The other thing that worries me is the tongue weight. They claim a low number... but we all know that other companies make claims about trailer weights that aren't realistic.
mcbrew is offline
Old 04-03-2011, 08:39 AM   #119
Trailer: 1980 Burro
Wouldn't that be "dumping the same load" 3 times?
Andy B is offline
Old 04-03-2011, 08:45 AM   #120
Ed Harris's Avatar
Nice!
Ed Harris is offline
Old 04-03-2011, 09:38 AM   #121
Cyndi B.'s Avatar
Trailer: 2010 Scamp 5th Wheel/2007 Toyota Tundra/2015 Tundra
Montana
It's bad enough when we have to empty the blue "tote" which could be a hazard in it self getting it to the dump station.
Cyndi B. is offline
Old 04-03-2011, 09:41 AM   #122
Cyndi B.'s Avatar
Montana
P.S. Riverside, Iowa is considering not having the Trek Fest this year.
Cyndi B. is offline
Old 04-03-2011, 09:45 AM   #123
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
This tread is getting way off topic.
Kevin K is offline
Old 04-03-2011, 09:58 AM   #124
Kip in Ga.'s Avatar
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Donna,
Thanks for the Video. Now I know!
Kip
Kip in Ga. is offline
Old 04-03-2011, 10:03 AM   #125
melissab's Avatar
Trailer: 2012 Scamp 13 DLX
Nose Shape
They have towed this prototype about 1000 miles and another one 5000 miles all over different roads, hills, highways and speeds with various vehicles and found no instability or affected handling. My Minvan being so low with further block airflow from going underneath. They also wanted to be sure the trailer didnt act like a wing (they are pilots and know all about lift) so they are satisfied the trailer is stable.
Melissa in Florida
2016 Honda Odyssey
melissab is offline
Old 04-03-2011, 10:56 AM   #126
Trailer: 1980 Burro
It is good to hear that they were thinking about it and have done some testing. Lift could be created if the air pressure under the trailer is greater than the pressure above the trailer. The shape at the front could create a ram effect increasing the pressure under the trailer. If the air has to travel a longer path going over the top of the trailer than going under the trailer that could also create lift, the same way that it does with a wing. The angle that the front faces into the wind will have an effect on this. It would not be very difficult for the manufacturer to install a load cell on the hitch and measure the hitch load while driving at different speeds, tow angles and with different vehicles. Testing 1 or 2 prototype trailers without instrumentation would not rule out problems or cover all the situations that may occur if there are hundreds of these on the roads. That said, there is probably no other trailer design that has been tested that way, but most trailers have the aerodynamics of a brick.
Andy B is offline
Closed Thread
lil snoozy
Lil Snoozy vs Scamp discussion (split from Classifieds) melissab General Chat 98 01-20-2013 12:03 PM
New Camper - Lil Snoozy Old Man Snoozy General Chat 7 08-08-2011 06:12 PM
See's Candy Dessert Recipes Donna D. Camp Cooking, Food & Recipes 3 11-09-2010 08:47 PM
