09-29-2015, 08:51 PM
#61
Trailer: 1989 Lil Bigfoot
CA
Originally Posted by Bob Miller
...more and more campgrounds, both public and private, are requiring a closed drain system, meaning a fitting to fitting hose between the RV and an external holding tank.
Bob, does the "rolling tote" qualify as an external holding tank?
Best,
EllPea in CA
09-29-2015, 09:45 PM
#62
Trailer: 13 ft Boler
We have a 13ft. Boler similar to the Scamp of the OP.
We have used it for over 10 years and made many mods
to it to fit our lifestyle.
We have a portapotty in it for emergencies only. We have always stayed at
camp sites with showers, etc and have enjoyed 99 percent of our experiences.
BUT I WANT A BATHROOM!!!
The best camp sites here are the provincial ones but they have the WORST amenities!
I would happily deal with the slinky as opposed to the outhouse!
I love playing in the dirt but like to shower after just as much.
Fred
09-30-2015, 08:16 AM
#63
Name: Steve in NY
Originally Posted by floyd
So walk when the conditions are right
We have a porta potti, as I mentioned. We haven't felt the need to use it yet, but we pull it out each night just in case. Times may change, and what's right for now might be wrong for then. In the meantime if somebody offered me a straight up trade for my 16 footer with sweet L shaped couch for one with a bathroom I would say no. It takes up way too much room for us, but we see the appeal.
Take Care,
Steve
09-30-2015, 09:49 AM
#64
Take Care,
Steve
I know the feeling, even though the 16Scamp is a great trailer and small by any reasonable standard, I just couldn't trade and live with three extra feet of unwanted space. The character of the Scamp13 and its utility had attracted me for decades before we bought our Scamp13D front bath.
We had a LoveBug with no bath before and loved it, but the couch seemed redundant compared to all the extra closet space, the microwave and of course the bathroom.
Afterall the interior is already nearly half seating/sleeping space, and that's with the bath.
I love all of the small fiberglass trailers with every available layout, each with its own appeal and advantages, but my Scamp13D,"Eggy-Sue" ( the pull-it surprize) has made my travel time complete with amazing efficiency.
09-30-2015, 09:56 AM
#65
Trailer: Class A Motorhome
Yes, IF there is a "Closed circuit between the outflow from the RV and the input to the tank". Meaning a mechanical hose connection of some sort at both ends, not just the hose stuck into an opening in the tote. Most totes have a garden hose fitting in the center of the large cap, if not you can get the parts at Home Depot, etc.
As a caution, you also will want to have an air vent somewhere for the tank or the sink may not drain well, and you will want to be sure that there is a trap on the sink or any orders in the the tank can come back into the sink.
09-30-2015, 10:35 AM
#66
...and you will want to be sure that there is a trap on the sink or any orders in the the tank can come back into the sink.
That's something I never thought about. The factory set-up on a Scamp without the optional grey tank just consists of a clear, flexible tube straight from the drain to the fitting on the exterior of the shell.
Bob, how did you plumb under the sink in your Hunter? I believe you use an external closed tank, right?
Also, how does Scamp plumb under the sink with the optional grey tank?
09-30-2015, 10:50 AM
#67
The factory set-up with or without the grey tank employs the sink drain/trap shown below, the rest is just routing of the tygon tubing.
09-30-2015, 11:02 AM
#68
The trap that Floyd shows above is the same one that I have used several times on RV's with direct drains. It works "Pretty good" and takes up minimal space under the sink. It's often sold as a "Tent Trailer" drain kit and includes a flexible drain hose and an outside fitting in the kit.
09-30-2015, 11:06 AM
#69
Thanks! I assume I probably have the same, but I'll have to check.
09-30-2015, 11:10 AM
#70
I can't yet speak for how it works in my total rebuild/redesign of the Scamp 16, but the front two feet are dedicated to the bath/toilet compartment. There are also compartments to either side since the bath area is roughly 24" deep X 37" wide. Here is a shot from the rear and there is approximately 20" to the right by the door for storage (hanging and shelves when finished.
to the left is the bottom utility area where the reel for the macerating pump and the J box for the trailer wiring are. There is also an accumulator tank for water pressure.
A removable door and shelf goes over these items for later access. There is also an access door to pull the hose out for emptying the holding tanks. I have run these with water from the grey tank, but not "really" used it yet.
I give up the settee and bunk that was here, but there will only be the two of us using the trailer. This arrangement gives 6' of height in the shower area with the lower shower pan and higher center part of the roof here.
One concern is that white drain/trap underneath. I think I am going to weld up a steel skid to protect this area, but I haven't done that yet. I have a pump like the newer Scamps to pump to the grey tank. The sink to the left has the fancy no trap rig for more space. Both the sink and shower drain to the same port on the grey tank the old side shower pan drained to previously.
The macerating pump is under the floor and is fed with 1 1/2" ABS pipe from the black and grey tanks. This is hopefully the low point for the system. Both of the tanks still have the 3" drain hookups if this doesn't work out for some reason.
My wife insisted on having a bath and one that she (6') could stand up in. This arrangement does that. As a matter of fact this was what drove the decision fot the 16' Scamp in the first place. The 16' Casita did not have enough headroom for her and the 17' was heavier than what we wanted to tow with the VW.
09-30-2015, 12:19 PM
#71
Trailer: Casita, previously u-haul ct13
Virginia
Back to the original question: I have a 13 footer camper and have always been a camping fool. Camping year round. Boondock mostly. I use an outdoor shower tent and a ZODI Hot water shower. All you need is a bucket of clean water and 6 batteries for the submirsable pump and propane cylinder. Works great! Also use a Porti Poti inside camper for nightly use. Just put chemicals in, Dispose of paper in trash can, NO SMELL, NEVER A MESS. Have used this system over 30 years. Many use the motos, " No muss, no fuss" or "Keep it simple stupid" Just do what works for you Diane. There is no right or wrong way...you will find your way.
09-30-2015, 12:24 PM
#72
Really nice kitchen counter and sink. Is that an IKEA sink?
09-30-2015, 01:47 PM
#73
Yes it is an IKEA sink and drain. The counter top is a Poplar 2' X ?' butcher block type panel from Lowe's stained with a mixture of several stains and pre-stain conditioner to get the color I wanted. It was then "varnished" with epoxy resin.
09-30-2015, 03:27 PM
#74
Originally Posted by Johnny M
I am kind of amazed at how this post about the facilities is such an active one... who knew???
Hi, the one about the sawdust porta potty installation went twelve pages before the moderator decided we'd had enough. Apparently this is an important issue, one every camper has to deal with, and one that probably deserves a lot of discussion...I know it's of interest to us! (Still looking for that perfect egg, and fascinated with the possibilities!)
09-30-2015, 04:05 PM
#75
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Greetings Diane and best wishes on your hunt for the perfect-for-you camper : )
For my wife and I? We wouldn't think of spending XX$$ on any rig without having the ability to shower and do-business. Even in our Van Conversion my MacGirlver of a wife managed to design, and then have Van Specialties of Portland, build her a bathroom-closet... ~18" deep from wall X ~30 wide when closed, and when open can be used as a private shower or powder/pottie room.
There are soooo many great ideas floating around this and other related forums that you are bound to find simple, affordable solutions for taking care of business.
Thom
10-09-2015, 08:55 AM
#76
Onboard bathroom involves lighting the water heater and pouring a shot of tank treatment down the toilet. Then use it for a week between visits to the dump station.
Sounds much more "Keep it simple stupid" and less "Rube Goldberg" to me, and the paper goes down the toilet!
10-09-2015, 10:00 AM
#77
We used (and still have) a Zodi shower unit that we used in the past with a shower tent until we added a water heater and an outside shower panel to both of our past 13'ers for showers when they aren't available in campgrounds. Works neat, we have it when we need it, and it's not taking up space when we don't. Ditto for the porta-potty vs a fixed bathroom.
As mentioned, different systems work for different peeps and, so far, none of them are "Rube Goldberg" at all, just different.
10-09-2015, 12:39 PM
#79
Unless you stash it in another accessible dimension, it takes up space whether you need it at the moment or not!
10-09-2015, 12:55 PM
#80
Yep, that's it's major drawback, but the Zodi unit only take up about the same space as a Group 27 battery box and is a lot easier to move and store than an entire bathroom.... LOL
