06-04-2013, 07:55 PM
NE Oklahoma
Battery Charged backwards
Can you undo a charging mistake?
Like hooking the charger to the battery backwards?
06-04-2013, 08:19 PM
New Jersey
Did it explode?
deryk
06-04-2013, 08:21 PM
NE Oklahoma
Nope. lol
06-04-2013, 08:43 PM
Trailer: Burro
Maine
What kind of battery, how many amps, how long attached? Do you get a voltage reading with a meter connected to it correctly?
Rich
06-04-2013, 08:50 PM
New Jersey
Yeah so what happened? Is there a problem? Is the battery holding a charge? How old is the battery?
deryk
You might check for blown fuse but other than that I have seen this a dozen times since Scamp uses black and white instead of red and black wires.
On a Scamp there is an inline fuse, Hopefully the same is true in your case.
Just replace the fuse and correct the polarity at the battery and things usually return to normal. Check the battery after a few hours to see if it is accepting a charge.
06-04-2013, 09:14 PM
Trailer: FunFinder
Depending on the charger, but for instance, a Deltran battery tender, like I use for my motorcylce batteries, have reverse polarity protection. So if you hook it up backwards, the chearger sees that, and does not even attempt to charge it.
06-05-2013, 07:45 AM
Those warning labels are only for the company that sells them anyway. (Joke)
You do know if you charge your battery backwards everything will go backwards. Even the bulbs will suck all the lite of the camper. (joke)
Guy next door tried to jump start his BMW with the p to the n and I caught him before it blew. I think you are lucky, maybe the inline fuse helped you out. Why don't you take your battery to be tested at the part store? Might be time for a new one any how.
06-05-2013, 08:10 AM
If you reverse charged the battery, you can try draining it completely, then recharging at the right polarity. It might be scrap, but it is worth a try.
06-05-2013, 09:03 AM
Trailer: Burro
Maine
If it is dead you could try a low trickle charge to the battery to see if it comes back. I drained an optima red top dead to absolute zero and trickle charged. I'm still using it 5 plus years later. It's at least from 2005 when I bought it. Point is batteries can take some abuse and if you are careful how you recharge them they might surprise you. I'm curious what it would due to a battery now. I'd be potentially more concerned about the charger and any electronics that might be have seen the reverse voltage. Though any positive voltage in the battery may have canceled it out at least in the equipments eyes. I'm not sure if reverse polarity would cause an over current but fuses only pop when excess current flows they don't know polarity.
Rich
06-05-2013, 10:54 AM
NE Oklahoma
Think I got lucky this time.
Actually, it's the battery on my mower.
It's a new battery. Seems my batteries don't stay charged.
May have to have my charging systems checked out. I had
trickled charged (2amp) for a few hours. When it would only
click I knew something was wrong. Then I noticed I had hooked
the cables up backwards (again). The previous battery had a
bad cell so it needed replaced anyway. I recharged it at 10amp.
When I went out after dark last night, the mower started back up.
I haven't checked it today, we got more heavy rain. I was going
to finish with my commercial mower and the battery was dead on it
as well. After realizing what I did, I double checked my commercial
mower. Luckily I had it hooked up right [with my old charger]. It's
the new charger I keep hooking up backwards. (2X). Need to mark
the cables extra ways.
My blood pressure had dropped in the low 90's so may have impaired me.
Blood sugar down to 77 at one point. Maybe I should have wife finish mowing....LOL
Anyway. Being an ex-mower repairman you think this wouldn't happen.
06-05-2013, 11:09 AM
Why?
06-05-2013, 12:42 PM
I took my post off because the other person did too
06-05-2013, 12:45 PM
T
LOL Carl there are lots of things that happen as I age that one would think shouldnt! The frequency of some of it is scary actually!!
Perhaps its time to label the battery to remember - I recently put a sticker on my trailers battery box regarding correct hook up as a reminder to myself and anyone else who happens to remove the battery.
06-05-2013, 10:55 PM
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Another mentioned the use of Black for Positive and White for Negative in some rigs...It stumps me as to why some in the RV industry began utilizing residential/commercial code wiring colors.
The first thing i did in my battery bay in the Parkliner was to correctly rewire all in the bay to automotive standard red/positive and black/negative on the 12 volt side in the battery bay. ( Yes i left the manufacturer's Black to + and White to - label with my own labels for the mods i did next to it). It was an easy afternoon project and didn't cost anything but some nice 8 gauge wire. No biggie. But sheesh! WHY??
06-06-2013, 09:39 AM
Its not actually "some" its most manufactures these days, if they are following the RVIA code. The RV industry looks at an trailer as a dwelling not a vehicle as it has no engine.
06-06-2013, 10:32 AM
I admittedly dont know what the motorhome standards are but it makes sense if the manufacture is following the RIVA standard in regards to the dwelling component.
Standards whether you agree with them are not, are actually a good thing, it sure makes it easier for people to fix something if they know it was built/wired to a specific standard. Problems can arise in the future on a trailer that lets say for example has a RIVA sticker on it and whoever is working on it in the future assumes it has been wired to that standard ... only to discover (often after the damage is done) that someone made changes to the wiring after it left the manufacturer's yard.
06-06-2013, 10:41 AM
I do have to ask! What does a lawn mower battery have anything to do with a camper?
Because I have a few things to ask about my TV cable box and about my zipper on my work boats..
06-06-2013, 10:42 AM
Astoria Oregon
I know the standard thingy/thought you've got going is correct Carol... i just wish the "Standard" had remained automotive...if it had wheels Ask any van conversion shop (that does not bow to RIVA hype) or professional auto alarm or stereo shop...they are all still seeing "Red" rather than "Black".
They are the ones most outspoken on the matter. If you go into our van conversion's wiring (professionally done) it is Red/positive following all the auto guidlines...until you get to the ceiling fan which has black as positive and white as negative from the factory. silly. ...red all the way to the black lead on the fan.
OH well, life goes on. At least i know what i'm doing in there and glad i'm not color blind!
And i luv you even if you might say Crick, when i might say Creek
Thom
06-06-2013, 11:22 AM
Thom
hummm I suspect the Queen would suggest with humour of course that you meant to say "Colour" blind oh and I thought it was our neighbours to the south that called it a Crick...
