Battery help please. - Page 2 - Fiberglass RV
Old 04-26-2015, 10:06 AM   #15
The positive wire for the Scamp is black as it is wired for lights and accessories, and passes through the shell leading to the battery. However, when that black positive wire gets close to the battery, Scamp soldered on a pale yellow 30-amp fuse holder wire. The other end of that holder is then fastened to the battery positive terminal. Therefore, you may not have a black wire ending at the positive battery terminal.
My '83 is the same as Mary Ann's, that is why I believe it is marked red and will be the second positive wire. The only difference is that both of my negative wires are white.
Scamper Jim is offline   Reply With Quote
Old 04-26-2015, 11:25 AM   #16
DaMScampers's Avatar
I had to totally retrace and redo all of my '96 Scamp Wiring. It was daunting but well worth it! Scamp (re)Wiring Diagram
DaMScampers is offline   Reply With Quote
Old 04-26-2015, 11:44 AM   #17
Originally Posted by Dan Meyer View Post
The factory Scamp wiring diagram shows the following:
Black - Battery positive
White - Battery negative
Red - Left stop and brake
Yellow - Back up lights
How does one turn right?
Old 04-26-2015, 04:18 PM   #18
To avoid problems, you will need to do a lot more investigating before connecting any of these wires to any source of power.
--Dan Meyer
Dan and Dawn's Scamp Travel Trailer
What's the difference between Stop and Brake???
Old 04-27-2015, 10:11 AM   #19
Mary Ann,
I occurred to me that since your TV electrical plug is connected to the camper plug, once you have identified the positive (hot) charging wire from the TV to the Scamp as described earlier, you will then be able identify both ground wires. One will give a reading because it is grounded to the frame, and the other will give a reading because it is the ground for the camper interior/accessories and grounds back to your TV through the plug.
Once you have identified the hot wire and the two ground wires, it is simply a process of elimination, so the forth wire must be the second hot wire. Those two can be connected to the positive battery terminal. The two ground wired are connected to the negative battery terminal.
4-plug Flat Connector:
Brown wire - Running/Marker lights
Green wire - Right turn/brake light
Yellow wire - Left turn/brake light
White wire - Ground
5-plug Flat Connector:
Brown wire - Taillights & Marker lights
White wire - Ground
Purple wire - Backup lights
7-plug Round Connector:
White wire - Ground
Blue wire - Brakes
Red wire - Auxiliary power
Old 04-27-2015, 06:44 PM   #20
Mary Ann in MN's Avatar
Trailer: 1992 Scamp 13' Deluxe
Thank you all for trying to help me with this.
Right now I can't think straight about any of this as I have a concussion and my entire body hurts from the accident. The hitch and all the frame work for the hitch is cracked and has to be replaced on the TV before I can use the camper.
I'm just thankful, it could have been much worse. The guy at the body shop said the way my hitch is saved me from getting hurt worse.
Thank God it was someone else's fault and their ins. Co. Has to pay for it.
Mary Ann & Butch
1992 Scamp 13' Deluxe, 08 Trailblazer
2011 Schnauzer "Butch"
God's Country, Minnesota
Mary Ann in MN is offline   Reply With Quote
Old 04-27-2015, 08:17 PM   #21
Mary Ann,
Very sorry to hear about your accident. Thank goodness you weren't hurt more seriously. Take good care of yourself and I’m sure you will also receive good care from your family. In the mean time, you have photos of previous camping trips to provide fond memories until you are able to enjoy camping again. Just let me know if I can be of any help in getting you and your camper back in the woods.
Best wishes,
Jim
Old 04-28-2015, 12:03 AM   #22
Originally Posted by Bob Miller View Post
If you look at your car you will find the (+) will often be marked red. (Old School (+) is HOT) Common practice in RV wiring is that (+) is black. This is why I never believe color codes when hooking up a battery.
The confusion may be for some due to Escapes being a wired a little different from the old school trailers such as Scamps. Discovered that this last summer while helping a friend with a battery issue.
On the Scamps the Black is the Positive and White the Negative. Scamp sells for $1 a waterproof decal which states that. I purchased one and stuck it on my battery box as I have had more than one person on occasion attempt to connect mine up backwards.
Old 04-28-2015, 06:20 AM   #23
Trailer: Escape 21 Nov.2016
batteries
We have the Lil Snoozy they put battery under couch with vents This is a lead acid battery . I would like to change out battery to an AGM 31 Do I need to vent this one or are they ventless?
Another question I wonder if I should put battery outside on tongue
Would a 100 watt Solar collector be good for this 105 Amp Hour battery ?
The battery that was supplied was a marine /RV series 24 65 amp hours
What other batteries could one use ? thanks JIm
jennykatz is offline   Reply With Quote
Old 04-28-2015, 08:40 AM   #24
Lots of people will suggest to you that they do not need to be vented but I would highly recommend reading the actual manufactures instructions in that regard as I know that at least one very popular AGM battery manufacture states on their instructions that they need to be vented.
Old 04-28-2015, 10:42 AM   #25
Since Scamp now has a sticker indicating black (+) and white (-), it indicates to me that they have probably wired the fuse holder closer to the camper shell, and resumed with a short piece of black wire to the battery positive terminal so there will now be a uniform color code. It's for us earlier Scamp owners who have to be careful how we hook up wires.
The wiring codes for the plugs I gave in an earlier post are from the towing vehicle side. As Don, Carol and the rest of us have probably seen, the wiring on the trailer side can vary with manufacturer and the color scheme preferred by the “Home Electrician Specialist” depending on whatever color wire he had handy. So you can't just rely on the "Color it is supposed to be", or the "Color it usually is" philosophy when working with electricity.
The photo of Mary Ann's wiring showing smaller gauge red and black wires indicates to me that is not something from Scamp. They use larger gauge as is done for the white and yellow wires seen. I hope the black wire grounds to the frame and not for lighting/accessories. If there is heavy resistance from some accessory, that wire could light up like a toaster wire and burn anything around it.
It's important to have a multimeter and continuity tester and know how to use them. They just may help keep you out of the auto repair shop and hospital emergency room.
Old 04-28-2015, 11:09 AM   #26
The decal has been available from Scamp for a number of years - at least 7 that I know of.
I have a 92 16' like the OP's that still has stock from the factory wiring - grateful for no PO make overs etc on the wiring.
It came with only the black and white lines coming off the battery and I agree something on the OP's has been changed as the gage size of the black wire looks wrong - thinner than the factory install. From the factory mine came with the inline fuse just off the battery as well as one just inside the house (buried under the rat fur in the passenger side front hatch).
Your correct that there is a short piece of wiring leading to the battery that taps into the main wiring harness before it goes into the house, which makes me wonder if someone changed out the wiring harness on the OP's trailer and got creative in using what wiring they had laying around in the garage to do the tap in.
Old 04-29-2015, 05:36 AM   #27
AGM batteries
We have the Schumacker XC6 Auto battery charger .If we get an AGM battery do i have to get another battery charger or change settings going from a lead acid 65 amp hr to a series 31 105 amp hours ?
Old 04-29-2015, 06:44 AM   #28
battery charger
I looked at the instructions for the XC6 and it does not support gel or AGM batteries ? So maybe just get a lead acid battery and put it outside on the tongue like casita,parkline, and scamps ?
The place Snoozy has the battery is cramped as it is ,so a 27-31 battery would not fit . If I put it under the bed I have to drill some more holes to let it vent
Does AGM batteries vent as much ? Jim
battery
Suburban GT6-3A furnace help, please. Raya Problem Solving | Owners Helping Owners 15 06-22-2012 10:08 PM
Advice please - how to wire a battery charger battery Steve_N_Janna Electrical | Charging, Systems, Solar and Generators 6 06-17-2012 04:53 PM
time to add a battery system, could use input please adriemel83 Problem Solving | Owners Helping Owners 20 08-14-2011 08:31 AM
Help...Bigfoot...Rare..please help! Tim Walliser Money Matters 15 05-03-2010 08:07 AM
Glastron Motorhome Please help! Scott Ss Classified Archives 1 05-31-2009 04:42 PM
