Since
Scamp now has a sticker indicating black (+) and white (-), it indicates to me that they have probably wired the fuse holder closer to the camper shell, and resumed with a short piece of black wire to the battery positive terminal so there will now be a uniform color code. It's for us earlier
Scamp owners who have to be careful how we hook up wires.
The wiring codes for the plugs I gave in an earlier post are from the towing vehicle side. As Don, Carol and the rest of us have probably seen, the wiring on the trailer side can vary with manufacturer and the color scheme preferred by the “Home Electrician Specialist” depending on whatever color wire he had handy. So you can't just rely on the "Color it is supposed to be", or the "Color it usually is" philosophy when working with electricity.
The photo of Mary Ann's wiring showing smaller gauge red and black wires indicates to me that is not something from
Scamp. They use larger gauge as is done for the white and yellow wires seen. I hope the black wire grounds to the frame and not for lighting/accessories. If there is heavy resistance from some accessory, that wire could
light up like a toaster wire and burn anything around it.
It's important to have a multimeter and continuity tester and know how to use them. They just may help keep you out of the auto repair shop and hospital emergency room.
