Battery Pack Generator - Fiberglass RV
Old 03-15-2016, 10:29 PM   #1
Fredericksburg Gold and Pawn has 2 battery generator packs, 1000w each with Inverters. Tel 5403717800
They are called the quiet, hum less generator.
My guess is that they have lylithum batteries inside.
Provide 12VDC, USB Charging Stations and 120 VAC output.
Old 03-16-2016, 05:24 AM   #2
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
Here is a link to one of those on Amazon:
Robot Check
Your RV battery and an inverter do exactly the same, for a heck of a lot less money.
[RANT]
These things should not be called "generators", they are simply a battery packaged with an inverter. A generator is something that converts mechanical energy to electrical energy, without storing it. That mechanical energy comes often from gasoline via internal combustion engine.
The battery in this device must be charged from a real generator, be it one that you bring along camping, or one that your trusty power company runs to give you your home electricity. It came from coal, gas, nuclear, hydro, solar, or such, and ultimately from the thermonuclear reaction in the Sun. Also, with every conversion, transformation or inversion and transmission, you get less and less out, a fraction is always lost in waste heat.
So, I wish the makers would actually tell people what it is. It smacks of false advertising, and if people believe there is something to it, I have a bridge to sell you.
[/RANT]
battery, generator
Battery pack group 24? margvv Care and Feeding of Molded Fiberglass Trailers 22 11-19-2015 12:01 AM
External battery pack for small speakers Craig D. Thompson Electrical | Charging, Systems, Solar and Generators 9 11-23-2013 06:26 PM
do i need to pack axle bearings on scamp '13 Dan Vang Care and Feeding of Molded Fiberglass Trailers 3 08-28-2009 09:59 AM
Xantrex power pack with solar panel Daniel V. Modifications, Alterations and Updates 9 03-05-2008 08:26 AM
Pack Mule Miriam General Chat 58 03-11-2007 04:38 PM
