big foot 17ft vs casita 17 ft - Fiberglass RV
Click Here to Login
Old 08-12-2009, 04:21 PM   #1
Does anyone have any info on how these two trailers compare to each other? I am considering purchasing one or the other and want to get all the info I can on them to help make a decision
Ted Schmidt is offline   Reply With Quote
Old 08-12-2009, 04:29 PM   #2
Roger C H's Avatar
Talking
You will be happy to know that Casita now has information on its website:
http://www.casitatraveltrailers.com/home.html
As does Bigfoot:
http://www.bigfootrv.com/bigfootrv_t...lers_2500.html
You can compare online!
Have fun!
Old 08-12-2009, 05:07 PM   #3
Trailer: 1991 17 ft Horizon
IMO and I stress that, I have never owned a Casita. But I have had several Scamps which you can compare them to ,with slight differences. I have also owned a 17.5 Bigfoot, and I would say the Bigfoot is in a totally different class. But I would also consider what are you using to tow the trailers. The Bigfoot is wider and heavier, and better built. If you have a big enough Tug I would go with the Bigfoot, but if you have a some what smaller Tug I'd go with the 17' Casita. If you can it would be nice to look at them both and see which layout you like. Good Luck with you Quest.
Old 08-12-2009, 05:19 PM   #4
brian m.'s Avatar
Trailer: 17 ft Casita Spirit Deluxe
Are you buying new or used? If buying new, Casita is still in business but Bigfoot is not. That may affect your decision. If buying used, go with what works best for you, price wise, tow vehicle size wise, karma wise...
brian
2003 Casita SD 17'
https://www.coolcampcreations.com/
brian m. is offline   Reply With Quote
Old 08-12-2009, 06:27 PM   #5
Robin G's Avatar
Trailer: 2007 Casita
Your from Montana? As others have said, knowing what your gonna tow with will help with that decision. Also knowing if you are camping alone, a couple, a family. Plus in my opinion the Casita and Bigfoot are two totally different trailers! It's like asking to compare a kiddie pool with a olympic size pool. (kinda anyway) Both are camping units with tires so you can pull them behind your tow vehicle. But each was made to fit into a different camping/rving style, price range, and ease of use. The Casita is perfect for ease of use! The easiest camping unit I have ever owned. But it's basic! The bigfoot was made for cold weather climate and because it's much bigger than a Casita there is more move around room, draw back is it's heavier, wider, etc. If you can/want bigger I totally suggest a bigfoot, if you want small compact then the Casita is the way to go! Let us know more about how you are going to use your trailer so that we may be able to help you find what your looking for.
Too bad you hadn't posted sooner, cause there have been several Casitas for sale in Montana in the last 6 months. Robin
casita
2003 17ft Casita $9000 Robin G Referrals: Molded Fiberglass Trailers 1 01-19-2010 07:17 AM
1986 Casita 17ft (?) $ 3500 Robin G Classified Archives 2 08-08-2009 06:24 AM
2002 17ft. Casita Spirit melinda w Classified Archives 5 08-07-2009 02:45 PM
2007 Casita 17ft $12500 Robin G Classified Archives 1 06-30-2009 06:01 AM
2007 Casita 17ft $13999 Robin G Classified Archives 1 05-27-2009 05:44 AM
