Bigfoot towing ? - Fiberglass RV
Old 11-25-2015, 04:46 PM   #1
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
Bigfoot towing ?
I currently have a EggCamper and I love it! But I have the opportunity to buy a 21 ft. bigfoot camper witch will give me the abality to camp in more extreme weather conditions. My current TV is a 2006 SAB it has a straight 6 in it. I cant afford to up grade my TV right now. What do you all think about puling it with this TV?
I hate to let my eggcamper go! I'm torn so I need your help!
Towing capacity: 5,500 to 6,500 lbs
Jason
If you think you are to small to make a difference just try sleeping with a mosquito –- The Dally Lama
kirkman is offline   Reply With Quote
Old 11-25-2015, 04:55 PM   #2
Those BigFoots can get a bit on the heavier side for FGRV's, especially with the all seasons kit. Here's some actual weights for a few, but options aren't shown.
Bigfoots, and this & that....
What is the exact model number of your Saab?
Old 11-25-2015, 05:15 PM   #3
kirkman's Avatar
Bob it's a 9 7x
Jason
Old 11-25-2015, 05:38 PM   #4
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
I can give you my experience with the '06 25RQ. I towed it with an '07 Nissan Titan King Cab 4WD. It had a 5600 lb curb weight. The 21 is about 5200lbs. The 21 also had issues with weight distribution contributing to sway, and the factory "fix" for it was to weld a couple of hundred pounds of ballast onto the tongue. I never really understood the 21' market... it was almost as heavy as the 25RQ, and was more cramped than the 17... the bed is a corner double that is hard to make.
Anyway I towed my 25 RQ some 20,000 miles in nine years with the Titan and came to the conclusion that the square frontal area was more important to the difficulty of towing than was the weight. And i wouldn't have wanted any less of a truck to tow the 25RQ with. I had a 7500 lb Ford Excursion V10 when I bought the Titan, and frankly I wish I'd never sold it as my tow vehicle. I don't see any reason that the 21 would be any different at all with a mere 400 lb difference in curb weight that is completely negated if it's had the sway "fix" ballast installed.
YMMV.
Old 11-25-2015, 05:58 PM   #5
kirkman's Avatar
Thanks Roger that was a huge help
I was worried about every thing you commentated about. Sounds like I should stick with my Egg for now and just burn more propane.
I really want a escape 5.0 any way. I just have to wait until the day I sell my home.
Thanks guys!!!!!!!!
Jason
Old 11-25-2015, 06:09 PM   #6
I sorta found the same thing, both on the BigFoot as well as on several Saab sites with posts about towing. It will be right at your towing limit and that "Fix" mentioned may exceed your tongue weight capacity.
I don't know if you can find the thread, but there was one about a 21' BigFoot that a lady in Utah bought with that added "Anti-Sway" fix and it wasn't kind to the solution.
Hopefully she or someone with the same trailer will respond.
May I suggest that you re-enter your thread with the entire BigFoot model in the title, it may draw better attention to that model. Something like "HELP BigFoot 21' towing info needed"
Good luck
Old 11-25-2015, 09:22 PM   #7
kirkman's Avatar
Thanks Bob I think I am just going to stick with my Eggcamper and wait until I can find or afford a escape 5.0.
Jason
Old 11-26-2015, 04:45 PM   #8
Trailer: Bigfoot TT
AZ
We tow our 2003 21'BF with a Ford F150 4x4 v8. Have had no sway issues thus far(Seattle through CA to AZ....so far). Had a 16' Scamp prior. Loved it, but a tad too small for us. Bigfoot is a great trailer.
dibot is offline   Reply With Quote
bigfoot
Towing Definitions-Understanding Towing weight terms cpaharley2008 Towing, Hitching, Axles and Running Gear 47 01-09-2019 01:53 PM
Towing like you're not even towing? swoosh Towing, Hitching, Axles and Running Gear 18 07-30-2015 09:18 AM
Liability and overweight towing (split from Towing 13' Scamp...) Bob Miller Towing, Hitching, Axles and Running Gear 88 04-18-2014 05:10 PM
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 02:04 AM
