Boondocking Tips?? - Fiberglass RV
Old 01-27-2013, 11:51 PM   #1
hotfishtacos's Avatar
Trailer: 2012 Escape 19' /2010 Honda Pilot 4WD TV
Escondido, California
Boondocking Tips??
Hello! We have been out on three trips so far with our new 19' Escape and have figured out where to put most everything in the trailer and and how to get setup and leveled for camping, etc. All of our camping so far has been great with full-hookups. Now we want to learn remote camping.
In two weeks we are going out to the Anza-Borrego desert and are going to claim "our spot" for a few days and have already scouted where we want to go. Our trailer is setup for this type of camping with solar, inverter, dual batteries, dual propane tanks, etc. My TV is a Honda Pilot 4WD with towing package so we can comfortably go off-road (carefully). What I could use are tips from you on how to preserve water and make the holding tanks last as long as possible before they top out, etc. and make the experience as enjoyable as possible. My goal is to become really good at camping off the grid when we want to go exploring. Of course we are on a steep learning curve. Any tips are appreciated. Thanks!
Steve
"No Generators"
hotfishtacos is offline   Reply With Quote
Old 01-28-2013, 12:21 AM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Steve, to conserve water, we have found a water saving device attached to the faucet (smart faucet, found at a marine store) that helped to cut our consumption by a third. All that is required is to unscrew the tip of your faucet's screen aerator and screw the smart faucet or similar device on in its' place. You leave your faucet hot or cold or both blended in the on position. Whenever you want water you just touch the lever and water is dispensed until the lever is released. It doesn't sound like much, but the scant amount of time used to twist on & off a faucet wastes more water than you would be aware of.
Old 01-28-2013, 01:56 AM   #3
nancyrwolfing's Avatar
Trailer: in the market
Where in Anza Borrego are you going, Steve? We have a new-to-us Casita in which we've been out 4 times so far, always with hook ups,, but we're headed to Quartzsite next week and will see how the boon docking goes. If it's a hit, w're thinking a trip out to Anza Borrego to admire and photograph the wildflowers would be a good one, so I'll be interested to hear more about your trip.
nancyrwolfing is offline   Reply With Quote
Old 01-28-2013, 08:53 AM   #4
Oh man I loved the Anza Borrego - wish it was me! It was the high light of my last winters trip. S2 is an interesting drive - stop in at Agua Caliente County Park for a swim in their hot springs pools. From there the little town of Julian is a cute place to check out as well. There is a GREAT bakery there. I dont recommend taking a trailer up to it though from the S2.
Some of the things I have done and bring along for off grid camping that have helped me stay in one spot for longer times are:
LED bulbs in all my lights
Small head lamps for reading at night
Carry a 10 gal portable tote for draining off the grey or black water tank as needed. Take it with you when sight seeing and you can usually find someplace to dump it - even if its only a gas station bathroom.
Carry a couple of small sized collapsible water containers for refilling the fresh water tank - you can pick up water for refilling water tanks while out sight seeing.
Carry a separate drink water container - which again can be refilled while out sight seeing.
Showering options - either sponge bath or if you use the trailers shower make sure you have a shut off right on the shower head handle and use it! :-) & carry a portable Solar Shower bag to use on a nice day and some eco friendly soap. The solar shower will heat up faster if you stick it in the tug behind a window or heat up some water on the stove and add it to the water in the bag works as well.
Use paper towels to wipe off dishes and pots before washing.
Using a plastic basin inside your kitchen sink helps a lot in making you be very aware of how much water you are actually using when doing dishes. There is also no harm in watering the local plants with the water you used for the final rinsing of the dishes, as it shouldn't have any food particulars of soap etc in it.
Have a great trip!!
Old 01-28-2013, 08:53 AM   #5
cpaharley2008's Avatar
To save on water we use paper plates and those little kits at fast food restaurants with knife/fork/napkins. This cuts down on washing dishes and the grey water. It is easier to bring home paper trash than 20 g. spare waste water tank that is full. I would also take some water in a 5 g water container for drinking/coffee. This leaves your fresh water tank capacity for discretionary uses.
Old 01-28-2013, 09:14 AM   #6
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I use one of those 1 qt generic spray bottles, fill it with water and use it to rinse off utensils, cups, whatever. Depending on circumstance I may be storing grey water which this keeps down as well.
Steve L. is online now   Reply With Quote
Old 01-28-2013, 09:26 AM   #7
Nancy I wished it had been spring rather than winter when I went to Anza! Would have loved to have been able to have photographed the wild flowers!
As mentioned previously I stayed at Agua Caliente and it would be a great spot to do some wild flower photos from & they offer electrical sites at a reasonable cost there if it turns out the dry camping doesnt fit your style. there are also spots just north of it just off the S2 where you can boon dock if you want. Box Car Canyon in that area also looked to me as if it has good spring flower potential.
At Borrego Springs the hike up the Borrego Palm Canyon behind the State park dry camping area into the Palm tree grove was an interesting area to photograph and I suspect would be even better in the spring. The dry camping in that state park was pricey - I think it was $25 a night - the hook up sites way pricier. But just outside of town a few miles there is a spot you will see from the highway where the boon dockers hang out. Some stay out for 4 or 5 days then go into the state park to dump their tanks and get a long hot shower before heading back out to the dry camp. If you havent already seen it, around the town of Borrego Springs runs a road with really amazing large metal sculptors by Richard Breceda also worth getting a shot of in the right light.
Old 01-28-2013, 09:50 AM   #8
To save on water we use paper plates and those little kits at fast food restaurants with knife/fork/napkins. .
Jim I am guessing you didnt grow up in a tree hugging community!
Most of the state parks as well as the private campgrounds you pass on your travels will let you for a small fee use their dumping facilities. Some highway rest stops also have free dumping facilities - at least here on the West coast I5 they do. Have found there is normally someplace to dump the tanks not to far away so have never had to pull to far with full tanks and have never had to bring waste water home to dump. A good website to bookmark on your smart phone is called sanidumps.com to find the closest dump station to you.
Old 01-28-2013, 10:00 AM   #9
GREAT idea Steve! I do that on kayaking camping trips and hadnt thought to do it in the trailer.
Old 01-28-2013, 10:35 AM   #10
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Steve, you say a few days. Just curious as to how many, as this makes a big difference in how we do things.
As well, will there be any outhouse, or similar facility. We are fortunate where we primarily boondock to have an outhouse set up.
Water conservation and use:
-We usually just sponge bath if out less than 5 days, with the rare exception of a quick shower using the shut-off at the shower head a lot. Using the outside shower does not accumulate water in the storage tank either.
-Dishes we almost always wash in a dishpan, and toss into the bushes. I have an affinity against using paper, not just to save a tree, but just that real plates are so much easier to use. We prewipe everything too, plus we don't rinse, but always dry immediately to remove any residue. Plus, we pack along a ton of dish towels.
-If no outhouse, the menfolk usually just water a tree.
-We take drinking water separate, used just for drinking and making coffee.
-On rare occasion we do take along an extra container of water, but really haven't needed that as there is usually a river or stream nearby.
-We have never had need in 5 days to empty the tanks either, using conservative measures.
Electrical
-With solar you really have no issues there
-We don't have solar, but with dual 6V batteries have never come near running low on capacity yet, even after 5 days using the furnace a bit.
-LED lighting will help a lot, especially if you have minimal daylight hours.
-We are conscious though of how much we use our lighting, as well as the furnace fan, keeping the heat down at night and snuggling under warm and cozy bedding.
Probably 80%+ of our camping is off the grid, something we have always done, and something I am used to from many years of traveling in the backcountry where a headlamp and backpacking stoves are the only electrical and gas products you have.
You will love this form of camping, the freedom and space it gives you is wonderful. When we can sit around the fire with our friends and family (usually 20 or more), play guitars and sing loud and proud, and have nobody to complain, it is great.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Most folks are about as happy as they make up their minds to be. Abraham Lincoln
Old 01-28-2013, 11:17 AM   #11
Take fire wood with you and take alot of it, it gets dark early.
Get a fire permit you can get one here before you go.
Sequoia National Forest - Recreation Passes & Permits
Permit is good on all California public lands except during fire restrictions. Beware if you have a fire the authorities will be looking for your permit. it isnt worth the fine.
Old 01-28-2013, 11:51 AM   #12
Trailer: 2015 Escape
In your original post you said preserve water but the replies you got are talking about conserving water. Is that what you meant or were you referring to keeping it good? If you meant good, you have nothing to worry about. It won't spoil. The tank, however if left damp for an extended period of time might or might not get moldy inside.
Old 01-28-2013, 11:55 AM   #13
If you are heading out for an extended periods and not wanting to pack a lot of fire wood due to weight issues a small propane fire pit works well. I have a Fire Dancer that I use. Very Light and packs up small. Often allowed to use it in areas that are under fire restrictions as well due to it being considered a propane appliance.
Old 01-28-2013, 12:01 PM   #14
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Watch out with the wood. Here in Minnesota we have a lot if Nasty Beasties that hitchhike on the bark. Emerald ash borer is killing off a lot of forests and its primary transmission mode is through firewood.
fusedlight is offline   Reply With Quote
boondocking
Beyond Boondocking Pam Garlow General Chat 2 09-25-2012 06:30 AM
Ideas on Boondocking Judith Kennedy Care and Feeding of Molded Fiberglass Trailers 24 06-28-2012 07:41 PM
Boondocking-What's it mean to you? Greg A General Chat 45 10-14-2007 09:30 PM
Boondocking in Canada Ann B Camping, Campout Reports 14 11-28-2006 02:10 AM
Boondocking without suffering Gina D. Modifications, Alterations and Updates 31 11-12-2006 11:53 PM
