Bottle Jacks - Fiberglass RV
Old 09-18-2008, 09:53 PM   #1
Trailer: 1998 17 ft Casita Spirit Deluxe / Red F150 X-Cab
When I had my last flat it was a pain in the neck using my truck's jack and wedging my Lynx levelers underneath for security (we had to change it on a slope, there was no flat area in sight). Should I get bottle jacks? Can someone explain how they work and it those are my best bet? Thanks! After some new tires, some other kind of jack is the next necessity!
Lisa M. is offline   Reply With Quote
Old 09-18-2008, 10:05 PM   #2
Gina D.'s Avatar
West Coast USA
I am not sure I would trust a bottle jack to lift that high and be stable for a tire change.
I used my Jeeps jack to change my flat (Near you!) and was comfortable enough to actually get in and out of the trailer with it jacked up.
I am no expert in them, but they impress me as something to use temporarily just to get the stab jacks under the frame. Bottle jacks are filled with hydrolic oil. Pressure from jacking forces the piston up and lifts. I have used my bottle jack to level and left the trailer on it, only to have to keep cranking on it as it looses compression over time (Less than an hour) I thought maybe the oil was low, but it still did that after filling it further.
Old 09-18-2008, 11:05 PM   #3
Roger C H's Avatar
Exclamation
I have a floor jack that I tried to use to remove a stump. It also is hydraulic. However, using it in a non-level position has caused it to get all out of whack. Apparently some oil got in the wrong place. What would be wrong with a nice scissors jack? Totally mechanical and smooth as opposed to a rachet type.
Old 09-19-2008, 06:01 AM   #4
I use a 12 Vdc electric sissors jack for all my jacking needs. It is a 2,000 pound jack so I can use it on the Escalade also.
Like this.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 09-19-2008, 10:08 AM   #5
Trailer: 2008 19 ft Scamp Custom Deluxe 5th Wheel
I plan on using the vehicle scissors. And tho I hate to carry extra "poop" I **will** add one jack stand. Just because.
Alan Weinel is offline   Reply With Quote
Old 09-19-2008, 05:59 PM   #6
Okay, I get it, what I need to buy are scissor jacks. I must have misunderstood someone I talked to. Those will be my next purchase. Thanks for your help!
Old 09-20-2008, 06:58 AM   #7
Go to a wrecking yard, and checking availability and pricing. Since it's not something you will use daily, purchasing new may be not in your best financial interest.
propane bottle JIM DUNNE Problem Solving | Owners Helping Owners 1 05-06-2009 06:17 PM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
Propane bottle options Myron Leski Problem Solving | Owners Helping Owners 18 07-20-2006 06:57 PM
Running Lamps/Stoves from LP Bottle Legacy Posts Problem Solving | Owners Helping Owners 13 03-19-2003 10:16 AM
propane bottle filler Legacy Posts Care and Feeding of Molded Fiberglass Trailers 20 02-07-2003 05:01 PM
