Bunks in a 13' Scamp - Page 2 - Fiberglass RV
Old 02-25-2014, 01:26 PM   #15
Scamp's answer
I called the factory to ask the very question. Their verbal answer was 150 pounds. Since nothing is in writing, I figure they haven't done any serious analysis or testing to back it up. So, I guess common sense rules. My Scamp is pretty new, so the ledge under the window appears solid (and, as noted in an earlier post, carries the weight, not the hinge). Another potential vulnerability I have wondered about is the bent carpenter's staple that is welded to the upright and catches the screw to support the front edge. Has anyone had any experience with failures there?
Old 02-25-2014, 01:58 PM   #16
Trailer: 77 Scamp 13
I called the factory to ask the very question. Their verbal answer was 150 pounds. Since nothing is in writing, I figure they haven't done any serious analysis or testing to back it up. .....
Well that is the most authoritive source I have heard from. "Scamp says" beat the heck out of "I think I read someplace". Thanks for taking the time to find out.
Old 02-25-2014, 02:36 PM   #17
Glad to hear Scamp was able to give you some weight indications... as said way better than I think I simple read it here! LOL
Re the welded piece on the support post.... well my trailer is a 92 and I know for a fact the couple who had it prior to me (i've had it 6 years) used the bunks all the time. The first two years I had the trailer I had the bunks always up. Now only use it a few times a year... so far no failure of the support post.
Old 02-25-2014, 04:31 PM   #18
CampyTime's Avatar
Trailer: Scamp 13' Standard
Hi Carol,
When spring finally arrives and you get the trailer open, would you mind sending a picture of the support post you added? Just wondering if it was another Scamp post and receiver, or if you crafted something yourself. Further, I wondered if you put it between the 2 support posts on the outer edge, or in another spot. Thanks a bunch!
CampyTime (Wendy)
Old 02-25-2014, 06:01 PM   #19
Wendy the post is the same one that Scamp sells (actually got it from them) and just added another of the round chrome base it sits in (same as the original) on the lower fiberglass bench. Just placed it bit closer to the centre of the bunk than the two originals were placed.
Looking for Scamp or Casita with two sets of bunks..open to other models Kyle2002 Wanted: Molded Fiberglass Travel Trailers 1 07-24-2012 11:38 AM
Adding bunks to a 13' Scamp HenryNorman Modifications, Alterations and Updates 10 04-25-2012 07:45 PM
OH | 2011 Scamp 16' w/ side Dinette, bunks, 5-sleeper-OH Bert Classified Archives 1 04-22-2012 10:07 AM
2006 Scamp Side Dinette w/front bunks - $8,750 BillE Classified Archives 2 09-27-2009 08:05 PM
2000 Scamp 16' toilet, bunks, a/c, hot h20,dual propane KirkG Classified Archives 2 07-05-2008 06:27 AM
