Can/do you "Dump" at home? - Page 2 - Fiberglass RV
Old 08-15-2014, 11:49 PM   #15
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Alice got a couple things for you. Do you know if the sewer main is in the street or in an easement to the rear? I ask that because most all sewer lines going from the house to the main will have a clean out not to far from the house. If you see a cleanout you know where the main is. They should have a screw in cap (for fumes). I've had a couple houses that had two inline, one sweep went towards the the street and the other toward the house. If you remove the cap you can see which way it turns. You can use the one going towards the street with no problem. If you don't see any cleanouts you can hire a private locater to mark the line for you. Possibly one of your neighbors may know. If it's not under concrete, cutting in a sweep for a new cleanout (dump station) is pretty easy. You can use Adams clamps to connect it to the existing line as a sewer line is not under pressure. When I added mine to my septic system I used an old water meter box and lid to enclose it.
Old 08-16-2014, 07:34 AM   #16
CampyTime's Avatar
Trailer: Scamp 13' Standard
I do have a clean out in my backyard where, with a longer hose, I could dump there. I don't do that though, simply preferring to use the dump station at the campground. Mines only a gray water anyway, mostly just dish soap bubbles and wAter.
Old 08-17-2014, 02:47 PM   #17
Trailer: 2015 Escape
When we had our house built I had a dump station installed. Since I live in the country it dumps into the septic tank. The bad thing is that I was not here when it was installed so the location is not where I would have had it put, with a bit longer hose, it works well.
Old 08-17-2014, 04:32 PM   #18
Wallo's Avatar
Utah
Thanks for the info. I know where the clean out is on the far side of the house from where Scamp is parked. It seems odd that it is there because the laundry room, kitchen, and master bath are on the side of the of the house where Scamp gets parked. I am going to check with the city this week and see if they have any info on clean outs attached to the main line. Would think in order to cut into the main line, or dump anything, one would need the ok from the city at minimum. Usually there is a cost involved plus and inspection. There are no easements to the rear.
Alice
Wallo is offline   Reply With Quote
Old 08-18-2014, 08:17 AM   #19
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I have the garden hose cap on the gray water. It gets dumped in the flower beds.
I can dump the black in my septic, but I've never used my black tank.
Old 08-18-2014, 10:29 AM   #20
my take on this....
dumping into septic system: Before doing that I would do a little research...your septic tank is a working "system"....that particular chemical you are adding to your black tank might just kill some of the desired organisms in your septic tank that make it work....lots of different holding tank chemicals out there....hence some research
adding a dump line on your property to a city sewer system: "don't ask don't tell"....it's your property....and even if there was something "wrong" with it, the "penalty" would probably less of a hassle than getting the approval beforehand....plead ignorance.... and take LOTS of pictures of the work/alteration
about things breaking up "down there"....just imagine what happens in that half full, small, square tank when you are driving down the road stopping, turning and accelerating...LOL...it's a regular washing machine....."don't sweat the small stuff"
Old 08-18-2014, 10:54 AM   #21
Timber Wolf's Avatar
North Florida
I had not thought about the chemicals. I suppose one could cut back to the minimum on them just to keep the smell abated. The other thought is a septic tank is pretty big and flushed with a lot of water from clothes washing and stuff and the few ounces of "blue" chemical dumped out of a black tank on a FGRV is a really, really small percentage of the total. In a sewer system it would a non-issue.
Old 08-18-2014, 08:16 PM   #22
Jared J's Avatar
Kansas
There are friendly treatments for black water, also.
Old 08-23-2014, 08:34 PM   #23
Trailer: Fiber Stream
Dumping at home
Originally Posted by Frederick L. Simson View Post
During this process I had him install a "clean-out" port (looks just like a campground sewer connection) in case I ever have to have the line Roto-Rooted. Its not very close to the spot where I park the Motel Fiber Stream (as my friends call it) but I have a 40' slinky that gets the dumping job done at home. I have to lift the slinky along it's length to get the waste to flow.
I forgot that the 2 pieces of the slinky total 50'.
Once connected up I have to start at the trailer and lift the hose off the ground, moving along the length toward the clean-out,
because of the up-hill part at the end.
I store my trailer in the back yard.Click image for larger version
First, the Doghouse...Click image for larger version
...is moved out of the way...Click image for larger version
...to access the clean-out.Click image for larger version
Find the tote...Click image for larger version
with the 50' sewer hose.Click image for larger version
Connect one end to the clean-out...Click image for larger version
...and the other end to the trailer across the yard.
Old 08-24-2014, 02:25 AM   #24
Frederick, I'm not sure by looking at the pics but is there any reason you can't back the trailer on the astroturf to be within 10 or so feet from the dump station ? I've done the slinky walk too and plumbed the one I have now to eliminate that.
Old 08-24-2014, 09:17 AM   #25
... is there any reason you can't back the trailer on the astroturf to be within 10 or so feet from the dump station ? I've done the slinky walk too and plumbed the one I have now to eliminate that.
I have access issues. While I do have a gate, I don't have a driveway. Once the trailer is parked in the yard it stays put. I have parked it on the astroturf when I had to park the Compact Jr in front of it. I have to practice "defensive parking" to keep some random neighbor from blocking access. Street sweeping day is the only time I can count on having access to the gate, and Robert has to act between 10:45 and 11:15 on Thursday to park HIS CAR in front of the gate. At 3300 pounds, the trailer is too heavy to move with a tongue dolly. The slinky walk is the least problematic solution, as building a curb cut, apron, and 6" thick driveway (to code) will cost me $10,000 - $15,000 (including permit fees). Such is life in the big city.
Old 08-24-2014, 09:20 AM   #26
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Unless we're gone for multiple weeks, I always dump at home. During the bulding of the enclosure for our trailer, I found a cleanout about 15 feet away. I'd much rather do this at home where I can take my time and do it right.
I understand that many people do not use their onboard facilities. For me, I'd sooner eat a frozen possum than use a public restroom. If I did not use our toilet, I'd take it out and put a hot tub or something in there.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
How Do You Move Tote Box to Sani Dump jimmied Plumbing | Systems and Fixtures 14 03-09-2013 08:48 AM
When you dump waste tanks on the ground Bruce H General Chat 29 04-13-2012 09:31 PM
Can anyone tell me if you can edit a title on a post? FRANK MOLIS Forum Admin, News & Announcements 1 08-21-2010 12:35 PM
Dry Camping: Fresh Water Sources and Dump Stations diannas Problem Solving | Owners Helping Owners 6 04-13-2009 04:34 PM
dump hose connector... Herb P Care and Feeding of Molded Fiberglass Trailers 3 07-05-2007 01:56 PM
