10-28-2013, 01:33 PM
Trailer: 1983 13 ft Scamp
Can you let a solar panel freeze?
I have a portable 80 watt solar panel in my trailer. I live in MN and sometimes we have 25 below zero weather.
Can I leave my solar panel in the trailer all winter?
10-28-2013, 01:45 PM
Absolutely. At least with all that I have seen.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
10-28-2013, 02:20 PM
Silicon is already frozen, (a solid). The freezing temperature of silicon is around 200°C.
10-28-2013, 03:38 PM
I know it gets cold in Minnesota Kevin but pretty sure not cold enough to damage the solar - or at least I hope not!
10-28-2013, 03:57 PM
They're Solid state..... Sorry . Raz
10-28-2013, 03:59 PM
yes…..
Jim
Never in doubt, often wrong
10-28-2013, 06:53 PM
Trailer: Oliver
Silicon actually changes state from a liquid to a solid (freezes or melts, depending on whether the temperature is going up or down) at 2,577°F (1,414°C)
Steve and Tali - Dogs: Rocky and our beloved Reacher, Storm, Maggie and Lucy (waiting at the Rainbow Bridge)
2022 Silverado High Country 3500HD Diesel 4x4
10-28-2013, 08:04 PM
Apparently that's what wikipedia says. I know that "solid state" devices get destroyed at around 200°C, many are rated at 125°C maximum operating temperature and 190°C maximum storage temperature. Could be the "doping" materials lower the melting point.
10-28-2013, 08:41 PM
Trailer: 1978 Trillium 1300
Cumberland, Indiana
So, am I to surmise that at 25 below zero the solar panel will be OK?
Spanke
Trilliums Rock!
10-28-2013, 08:49 PM
Yes, heat destroys electronics but probably not by causing damage to the silicon. Lead, which was a major componet of solder, melts at 183°C. The newer lead-free stuff melts at around 200°C. In any event, if they get too hot the components will literally melt apart.
Cold is usually not a problem with electronics. In some devices (like heat-seeking missiles), they are in contact with liquid nitrogen at −195.8 °C.
10-28-2013, 08:54 PM
Normal winter temps up here.
2017 Escape 5.0 TA
10-28-2013, 08:59 PM
Trailer: asdf
Alabama
It is more likely the fine gold wires which connect the chip to the pins. Or other components inside of the chip. There are all kinds of things other than just the IC itself embedded in an IC. Resisters, capacitors, etc.
10-28-2013, 11:33 PM
FYI,,, There's no solder inside semiconductor devices. The gold wires are sonic welded to the silicon and the carrier. Correction, the only solder inside a semiconductor device is the solder that holds the silicon (chip) the carrier.
10-29-2013, 06:21 AM
Thus the name,Integrated Circuit ?
10-29-2013, 07:43 AM
Trailer: asdf
Alabama
Yes of course. However I was actually talking about individual components bonded to the carrier of the IC.
IC is one of those words which is contextual. There are thousands of ICs created on a slice of silicon. In that context the IC also has resistors and capacitors as well as transistors, formed right on/in the silicon.
Break those ICs into individual units and they are then bonded down to a carrier, essentially a miniature circuit board, where other individual components are added. This carrier is then installed in a plastic (or ceramic) body which is what you see. Most people think of and call those ICs as well. It is this level that is damaged by the heat. OTOH the interior piece of silicon is often damaged by static electricity, another discussion entirely.
10-29-2013, 07:51 AM
Mmmm! Frozen solar panels...Taste Gooood!
Okay, this post isn't helpful.. Skip right over it.
10-29-2013, 08:00 AM
Trailer: asdf
Alabama
LOL. You coulda put the last line first!
10-29-2013, 08:31 AM
Spanke
Well Spanke in theory it should or at least its the theory of a bunch of folks on the internet whom you have never meet. YMMV
10-29-2013, 10:05 AM
The solar cells on the Mars rovers get way colder then any on Earth.
10-29-2013, 10:07 AM
Trailer: asdf
Alabama
no doubt. However they aren't "consumer grade" either.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Solar Panel Set up Question - Grounding the panel?
Anne H |
Electrical | Charging, Systems, Solar and Generators |
2 |
09-07-2012 04:48 PM |
solar panel
h.mike |
4 |
07-17-2012 09:01 AM |
solar panel
Judith Kennedy |
2 |
10-29-2009 11:30 AM |
solar panel help
Maggie |
9 |
07-18-2006 04:38 PM |
