Can you let a solar panel freeze? - Fiberglass RV
Click Here to Login
Old 10-28-2013, 01:33 PM   #1
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
I have a portable 80 watt solar panel in my trailer. I live in MN and sometimes we have 25 below zero weather.
Can I leave my solar panel in the trailer all winter?
Old 10-28-2013, 01:45 PM   #2
Jim Bennett's Avatar
Absolutely. At least with all that I have seen.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 10-28-2013, 02:20 PM   #3
Silicon is already frozen, (a solid). The freezing temperature of silicon is around 200°C.
Old 10-28-2013, 03:38 PM   #4
I know it gets cold in Minnesota Kevin but pretty sure not cold enough to damage the solar - or at least I hope not!
Old 10-28-2013, 03:57 PM   #5
Raz
Raz's Avatar
They're Solid state..... Sorry. Raz
Old 10-28-2013, 03:59 PM   #6
cpaharley2008's Avatar
yes…..
Jim
Never in doubt, often wrong
Old 10-28-2013, 06:53 PM   #7
Steve Outlaw's Avatar
Trailer: Oliver
Silicon actually changes state from a liquid to a solid (freezes or melts, depending on whether the temperature is going up or down) at 2,577°F (1,414°C)
Steve and Tali - Dogs: Rocky and our beloved Reacher, Storm, Maggie and Lucy (waiting at the Rainbow Bridge)
2022 Silverado High Country 3500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 10-28-2013, 08:04 PM   #8
Apparently that's what wikipedia says. I know that "solid state" devices get destroyed at around 200°C, many are rated at 125°C maximum operating temperature and 190°C maximum storage temperature. Could be the "doping" materials lower the melting point.
Old 10-28-2013, 08:41 PM   #9
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
So, am I to surmise that at 25 below zero the solar panel will be OK?
Spanke
Trilliums Rock!
Old 10-28-2013, 08:49 PM   #10
Yes, heat destroys electronics but probably not by causing damage to the silicon. Lead, which was a major componet of solder, melts at 183°C. The newer lead-free stuff melts at around 200°C. In any event, if they get too hot the components will literally melt apart.
Cold is usually not a problem with electronics. In some devices (like heat-seeking missiles), they are in contact with liquid nitrogen at −195.8 °C.
Terry G is offline   Reply With Quote
Old 10-28-2013, 08:54 PM   #11
Normal winter temps up here.
2017 Escape 5.0 TA
Old 10-28-2013, 08:59 PM   #12
Trailer: asdf
Alabama
It is more likely the fine gold wires which connect the chip to the pins. Or other components inside of the chip. There are all kinds of things other than just the IC itself embedded in an IC. Resisters, capacitors, etc.
jwcolby54 is offline   Reply With Quote
Old 10-28-2013, 11:33 PM   #13
FYI,,, There's no solder inside semiconductor devices. The gold wires are sonic welded to the silicon and the carrier. Correction, the only solder inside a semiconductor device is the solder that holds the silicon (chip) the carrier.
Old 10-29-2013, 06:21 AM   #14
Ed Harris's Avatar
Thus the name,Integrated Circuit ?
Old 10-29-2013, 07:43 AM   #15
Trailer: asdf
Alabama
Yes of course. However I was actually talking about individual components bonded to the carrier of the IC.
IC is one of those words which is contextual. There are thousands of ICs created on a slice of silicon. In that context the IC also has resistors and capacitors as well as transistors, formed right on/in the silicon.
Break those ICs into individual units and they are then bonded down to a carrier, essentially a miniature circuit board, where other individual components are added. This carrier is then installed in a plastic (or ceramic) body which is what you see. Most people think of and call those ICs as well. It is this level that is damaged by the heat. OTOH the interior piece of silicon is often damaged by static electricity, another discussion entirely.
Old 10-29-2013, 07:51 AM   #16
Steve L.'s Avatar
Mmmm! Frozen solar panels...Taste Gooood!
Okay, this post isn't helpful.. Skip right over it.
Old 10-29-2013, 08:00 AM   #17
Trailer: asdf
Alabama
LOL. You coulda put the last line first!
Old 10-29-2013, 08:31 AM   #18
Spanke
Well Spanke in theory it should or at least its the theory of a bunch of folks on the internet whom you have never meet. YMMV
Old 10-29-2013, 10:05 AM   #19
David Tilston's Avatar
The solar cells on the Mars rovers get way colder then any on Earth.
Old 10-29-2013, 10:07 AM   #20
Trailer: asdf
Alabama
no doubt. However they aren't "consumer grade" either.
solar, solar panel
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
solar panel h.mike Care and Feeding of Molded Fiberglass Trailers 4 07-17-2012 09:01 AM
solar panel Judith Kennedy Problem Solving | Owners Helping Owners 2 10-29-2009 11:30 AM
solar panel help Maggie Electrical | Charging, Systems, Solar and Generators 9 07-18-2006 04:38 PM
