Carrying water - Fiberglass RV
Old 09-27-2014, 07:57 AM   #1
Trailer: Parkliner
Carrying water
I am so new at this trailering business and have a couple of questions that are probably elementary. If I am going to a place with no electricity is it OK to carry water in the tank while driving? Also, does anyone use a Chrysler Town and Country to tow with? They told us that the van does not charge the battery while driving, which it does not. Can't quite figure out if I am out of luck or if there is a way to fix it.
Thanks
Pat
Pat in Michigan is offline   Reply With Quote
Old 09-27-2014, 08:12 AM   #2
honda03842's Avatar
Name: Norm and Ginny
We always carry a half tank of water useful in emergencies and for bathroom use. When we reach a camping sight we will often fill it.
Town and Country vans do make good tow vehicles, though you did not mention the year or configuration. Generally tow vehicles with automatic transmissions need the addition of a transmission cooler.
Every tow vehicle I know can charge the trailer battery while driving. It does require a wire to be connected from the plus side of the battery to your 7 pin connector. In my case I pick up the plus side of the battery using an open fuse position in the fuse box and a special fuse. If you're interested in these fuses with a conveniennt wire coming off them let me know and I'll dig up the link.
Generally when towing I increase the pressure in my tires, particularly the rears, This helps prevent the trailer from pushing around the tow vehicle.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-27-2014, 08:14 AM   #3
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Hi Pat, you can carry all the water you want to. To each there own, we carry drinking water for coffee and such. Which we can refill at most grocery stores if need be.
Not sure if you have a seven pin connector or not. If so, it will make it easier to add 12 volt line to charge your batteries. I'm not going to go into detail on how to do that. Any good trailer place or U-Haul can do it for you .
I know you just got your trailer so, remember if you have used your water systems? They will need to be winterized.
Old 09-27-2014, 08:46 AM   #4
TomK's Avatar
Hi Pat. We're noobs too. We have a city water connector, and a hand pump on the sink instead of an electric pump. We carried 5 gallons of water in the tank to Algonac. The tank was filled at home for making coffee, tea, etc. where taste matters, and we operated with 5 gallon cans at the picnic table for other cooking and cleaning needs. That seemed to work fine. Nothing wrong with carrying some water. Like Mike said above, start thinking about winterizing your trailer. One good hard overnight freeze can do some damage to your plumbing.
Say hi to those nice dogs of your's for Joanne and I.
Tom
Old 09-27-2014, 09:23 AM   #5
honda03842's Avatar
Town and Country Towing
Here are a couple of links ro Town and Country Towing
Can-Am RV Centre | Your Towing Experts
Venture RV Sonic 190VRB - RV Lifestyle Magazine
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-27-2014, 09:29 AM   #6
Saskatchewan
What kind of plug is it on the Town and Country? 4 flat or a larger 7 pin? If it is the 4 pin, getting the charge line to the trailer battery is a little bit of work as you would have to change the ends on the van and trailer. If you have the 7 pin, half the work is already done and that need to be done is have the charge line wired from the battery to appropriate pin on the plug.
What, a little note about the Town and Countries/Caravans, they are only rated for 1200 LBs with out the aux oil cooler. A strong suggestion would be to add an auxiliary transmission cooler. I have to recheck my books but I think there may be an engine oil cooler that can be installed.
As for carrying water, for me it depends on how far and where. My tugs are both more then capable of towing an egg with a full tank. I tend to use my blue water jug more though as I don't really use the sink of stove inside.
Orcus79 is offline   Reply With Quote
Old 09-27-2014, 09:44 AM   #7
I camp often at locations with no hook ups and whether or not I fill up my tanks ahead of time depends a lot on how far I am going. If traveling a fairly long distance I don't fill the tanks until i am getting close to my destination. Figure the lighter the trailer the better MPG's I get and water does add weight which is something you need to watch in regards to trailer stow and the location of the tanks. On my Scamp for example the water tank is at the very rear of the trailer so when full I need to make sure I have enough extra weight on the tongue of the trailer to compensate for it.
Old 09-27-2014, 11:42 AM   #8
Wallo's Avatar
Utah
I carry a 5 gal. container in the back of my vehicle while traveling. Then fill up the fresh water tank at the campground when I get to my destination. The trailer seems to handle better, and less weight. (It's about 80# for a 10 gal. fresh water tank). I have run into situations on the Interstate that caused me to make a swerve. The water in the tank made the swaying of the trailer more pronounced and difficult to control. (Have you ever walked a heavy, full pan of water from one side of the room to another? Slosh, Slosh.)
Alice
Wallo is offline   Reply With Quote
Old 09-27-2014, 02:52 PM   #9
Trailer: 2015 Escape
I towed my EggCamper with a Chrysler mini van and it did a fine job. If you have the flat plug go to an RV place or a Uhaul place and have them replace it. I wouldn't worry about the weight of the water. Unless you're doing a lot of stop & go driving or a lot of uphill, the water will have a negligible effect on your mpg. wind resistance is what knocks your mpg down. I usually start from home with a full tank. i can't imagine sloshing water causing swaying unless you don't have enough hitch weight.Even with it sloshing, it seems to me that the tank would be small enough that not a lot of movement of water would cause anything. I've been towing for over 50 years with various trailers and never had any sway. No anti sway device either.
Old 09-27-2014, 03:05 PM   #10
honda03842's Avatar
Water and Miles per gallon.
The effect of water weight on miles per gallon is minimal in these small trailers.
First, even a full tank of Scamp water weighs about 2% of the total weight of the trailer and tow vehicle (100 of 6600). This is weight of water is trivial compared to the tailer/tow vehicle.
Second the primary tow vehicle load at any practical speed is air resistance.
The sloshing effect of the amount of water we carry is relatively small compared to trailer mass. We drive with a very light tongue weight (7%/200 pounds) and water has never caused an instability. ALso water is not moving from one side of the trailer to the other, on average the water moves less than a foot.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-27-2014, 03:28 PM   #11
Mike Magee's Avatar
Trailer: Li'l Hauley
I am guessing that the UHaul only has the flat 4-pin connector. Not sure if there is a converter in those trailers; any other UHaul owners know for sure? A trailer place could fix you up with new connectors and a charge line.
How to prepare Tofu
Step 2: grill some meat
Old 09-27-2014, 07:29 PM   #12
Trailer: Parkliner
Thanks everyone for all the help, Norm and Ginny, I drive a 2014 Town & Country with a tow package so it has a 3500 lb tow capacity. I guess I misunderstood the 7 pin connector problem. Hubby said the problem is there is no fuse for the lead that should charge the battery (I think). I Tom and Joanne, hope all is well with you.. Thanks for the winterizing reminder, one more question. If I winterize my trailer and decide to go somewhere do I have to flush it all or do you just not use any of the water?
Old 09-27-2014, 07:34 PM   #13
honda03842's Avatar
Here's an easy and convenient way to get a fused wire.
Add A Circuit ATM Mini Blade Style Fuse Tap 5 Pack Ford USA Seller | eBay
They are available for different makes.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-27-2014, 08:04 PM   #14
Trailer: Parkliner
Thanks Norm and Ginny
parkliner
Carrying a canoe while towing a trailer; recommendations? Des Nolan Towing, Hitching, Axles and Running Gear 8 10-16-2010 05:43 PM
carrying bikes Rarebird Problem Solving | Owners Helping Owners 31 07-27-2009 07:55 AM
Carrying Bikes Lainey Problem Solving | Owners Helping Owners 8 08-29-2007 03:33 PM
purchasing/carrying bicycles, what kind is best/carry inside camper? Marla General Chat 18 11-11-2006 04:40 PM
Carrying the generator and fuel.... Lizbeth Problem Solving | Owners Helping Owners 18 08-12-2006 10:45 PM
