Originally Posted by allen jackson
I have towed single and tandem axle boat trailers and always found the tandem axle trailers to be more stable and easier to back up, but maybe that's just me.
Properly setup, tandem axles do increase stability - the two axles are always fighting each other when you turn, so they are always trying to keep the trailers going straight. They problem is only when you let them go nose-down... that was what I thought might have been the issue with the fishtailing
U-Haul.
I don't get how backing up a tandem is better - the stupid things just resist turning.
It may be that for most people with single-axle and tandem-axle experience, the tandems are the longer trailers (they're bigger, which is why they have another axle), and longer trailers are indeed easier to control in reverse. I rented a tandem-axle
U-Haul recently which was not much shorter than our
Boler: it wasn't particularly easy (nor difficult) to back up.
