Casita - Fiberglass RV
Old 09-21-2013, 05:12 PM   #1
allen jackson's Avatar
Trailer: 2005 Casita SD 17'
Arkansas
Casita
What is an approximate list price of a new fully loaded 17' Casita?
Also, does the published length include the tongue of the trailer and the rear bumper?
allen jackson is offline   Reply With Quote
Old 09-21-2013, 05:56 PM   #2
Brian B-P's Avatar
Yes, all of the current moulded fiberglass travel trailer manufacturers follow the convention of measuring the complete overall length, including tongue and bumper.
Old 09-21-2013, 06:42 PM   #3
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
Base price is $14,000. Most new owners add several thousand dollars in options.
Casita Travel Trailers - Frequently Asked Questions | Two Shell Construction, Fiberglass Finish, Channel Steel Frame, Warranties
Old 09-21-2013, 07:12 PM   #4
Ian G.'s Avatar
$14,000 would be for a base 13' For the more popular 17' deluxe you would be looking at $18,000-$20,000. The deluxe versions are very well equipped with full bathroom and shower, air conditioning, etc. as standard features Most add options like an awning, furnace, high lift axle and upgraded tires.
Old 09-21-2013, 07:24 PM   #5
Hi Allen, to FiberglassRV, we're glad you're here
There's lots of kind and helpful people here on the forums and as you can see, they've already started replying.
Old 09-22-2013, 05:58 AM   #6
Arkansas
I am 4 1/2 hours from Rice, TX. We may visit Casita this week. I have considered buying used, but really want no more problems or issues to have to deal with than necessary. Parking space at home is limited and we have an older tow vehicle that is only rated for 5,000 pounds. It's a great truck and I don't want to part with it. I also am not wild about the vinyl roofing and wood framing on conventional trailers. I like Casita construction and also the fact that sales are done in house and we would not have to deal with typical RV dealers. I just wanted a ballpark dollar figure. Thanks guys.
Old 09-22-2013, 06:08 AM   #7
cpaharley2008's Avatar
Welcome to FGRV Allen,
Your tow vehicle will do fine with the Casita, please keep us posted with your decision and take pictures when you visit the factory to get your new little home.
Jim
Never in doubt, often wrong
Old 09-22-2013, 04:22 PM   #8
Brian B-P's Avatar
Your tow vehicle will do fine with the Casita...
Likely yes, but some of members - with newer full-size pickup trucks - have found the tongue weight of a Casita 17' excessive, especially in combination with their passenger in-truck cargo load. This model runs unusually high in tongue weight for its size.
Old 09-22-2013, 04:32 PM   #9
Arkansas
I used to tow a 4,000 pound boat and trailer with a 300 pound tongue weight, so that doesn't bother me too much. 10% of towed weight for tongue weight used to be the rule of thumb, so I guess 300 pounds is a little more than 10% of a Casita. If necessary, it's pretty easy to have leaf springs arched or add a leaf on a pickup truck with leaf spring rear suspension.
Old 09-22-2013, 06:43 PM   #10
Brian B-P's Avatar
Yes, but although a Casita 17' can weigh as little as 2210 pounds (dry and empty), that same weight goes with a 295 pound tongue weight (13%) - see Casita's specs. Any real Casita 17' - with options, water, propane, and your stuff - will have far more than 300 pounds of tongue weight. That might not be a problem, but it's the factor that keeps the answer to "is it okay for my truck to tow" from being an automatic "yes".
Other similarly sized trailers - the 16' from Casita and various models from other manufacturers - tend not to be so tongue-heavy.
Old 09-22-2013, 07:01 PM   #11
Ian G.'s Avatar
Don't let the slightly higher tongue weight of the Casita scare you Allen.
Many owners simply install a weight distribution hitch which works very well.
My Tow vehicle is a 2008 V6 4Runner, I use the Reese SC (sway control) weight distribution system and I am very impressed with the hitch, it rides level with no suspension modifications and has no problem pulling the mountain passes of the Canadian Rocky Mountains.
Reese SC Weight Distribution with Sway Control Review - etrailer.com - YouTube
Old 09-22-2013, 07:54 PM   #12
tractors1's Avatar
Trailer: Escape 21 - Felicity
Ditto here on a 17LD with the weight distribution hitch. 2013 Tacoma V6 4x4 doesn't seem to care it's behind us, except on 6-8% grades.
Just returned from Oregon to Southern Utah trip and averaged 15.5 mpg.
Charlie Y
Charlie Y
Old 09-22-2013, 08:04 PM   #13
Trailer: 2010 Escape 17B
When we weighed our Casita 17 in the summer it was total weight 3220 packed for a short trip. Tongue weight of 380 with empty tanks I believe. If the water tank had water in it, it should reduce this but haven't tried weighing it like that yet. My hubby hates going to the scales so it is a battle every time
We tow with a honda ridgeline towing capacity 5000 lbs no WDH.
kootenaigirl is offline   Reply With Quote
Old 09-22-2013, 11:26 PM   #14
MarkyVasquez's Avatar
You might want to look into the Scamp trailer also. It's very similar to the Casita but it's lighter and the hitch weight is also a lot less. Scamp doesn't make a 17' but they do make a 16'. I'm not too sure what the base price is, maybe some can fill you in on that.
MarkyVasquez is offline   Reply With Quote
casita
OH | 2000 Casita Spirit Deluxe Near Dayton $7,500 or trade for 17' Liberty Casita pwdohio Classified Archives 15 07-29-2013 05:02 PM
No Longer - Trade 17' Casita for 13' or 16' Casita, Scamp, pennyg Classified Archives 11 03-04-2007 09:38 PM
Inside Casita by Casita (Pic) General Chat 0 01-01-1970 12:00 AM
