Casita High Lift Axle - Fiberglass RV
Click Here to Login
Old 09-16-2007, 05:36 PM   #1
Trailer: Airstream 16 ft OB
What is involved with the high lift axle option offered by Casita? Is it nothing more than a standard axle that is lowered about 1" by adding some square tube steel between the axle mounting and frame?
Steve R is offline   Reply With Quote
Old 09-16-2007, 05:44 PM   #2
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft / Dodge 3500HD 4X4 Jake Brake
NO, it is NOT a spacer between.
The High lift axles has a greater down angle to the swing arms giving about 2” greater ground clearance. My 17’ Casita never drags going in and out of drive ways and gas stations.
Old 09-17-2007, 09:27 AM   #3
Robert Brummett's Avatar
Trailer: 2003 17 ft Casita Spirit Deluxe
Send a message via AIM to Robert Brummett Send a message via MSN to Robert Brummett Send a message via Yahoo to Robert Brummett
Especially useful with 15" tires IMO.
Robert Brummett is offline   Reply With Quote
Old 09-17-2007, 04:56 PM   #4
Brian B-P's Avatar
That means it is even less than just a spacer... it's a no-cost (to Casita) order option on the axle assembly. It is good to have a choice!
If replacing the axle on a used trailer (Casita or otherwise), you would have the same option available.
Old 09-17-2007, 07:48 PM   #5
Pete Dumbleton's Avatar
Mike, I can almost see the photo posted by Pine Cone Don, IIRC, that clearly showed a piece of C channel welded between the C channel frame and the axle bracket a few years ago.
Old 09-17-2007, 07:54 PM   #6
My first replacement High Lift Axle.
YES, before Casita made the High Lift Axle available, people were adding spacers to gain more height.
I replaced my first axle with a high lift axle after I bought my 17’ 2001 Freedom. Then when I bought my new 17’ 2004 Liberty, it came with the high lift axle.
The axle makes a big difference. I also replaced the 14” wheels with 15” wheels and tires.
Old 09-19-2007, 08:02 AM   #7
ronsmith100's Avatar
Hi Zeb
I have an 06 SD that I ordered with the high lift.
I just finished putting shocks on in the process got real familiar with the Dexter company who makes the axle.
As the picture below shows there is an angle between the wheel spindle and the axle. Dexter makes these in many sizes and casita gets the high lift by just installing one with a greater down angle.
I have been under there so many times I can't see a reason why you couldn't add another steel tube to get an extra lift.
Ron
ronsmith100 is offline   Reply With Quote
axle, casita
Axle winterizing... To lift or not to lift??? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 22 12-12-2015 06:47 PM
High Lift Axle Daniel W Care and Feeding of Molded Fiberglass Trailers 6 03-24-2010 06:46 AM
Casita high rise faucet spout Morgan Modifications, Alterations and Updates 18 02-14-2010 04:07 PM
High lift axel Chris C General Chat 7 12-05-2005 05:30 PM
Casita Hi Lift axle Legacy Posts General Chat 6 06-08-2003 04:06 PM
