Casita Rear Bed Question - Fiberglass RV
Old 01-21-2007, 07:16 PM   #1
Karalyn's Avatar
Trailer: Eggless for now but looking. currently own Amerilite 21 ft
I was reading some information about those Walmart memory foam mattrices and wondering if anyone has ever tried them in a 16 FT Casita?
I read somewhere that they work in the 17 ft Casita, but not sure that rear dinette/bed is the same size in the 16 ft model. Anyone know?
Karalyn
Old 01-21-2007, 07:47 PM   #2
Trailer: Fiber Stream
Talking
"Bed Size" topic link no.1
"Bed Size" topic link no.2 (old, Legacy Post)
Old 01-21-2007, 08:13 PM   #3
If it's JUST the memory foam (or any other foam), it's EASILY cut with an electric knife.
Old 01-21-2007, 10:00 PM   #4
Karalyn's Avatar
I was thinking of getting an 8" thick one with a cover on. That could not easily be cut with a knife. I have a one inch one and that I did cut some. I am ondering if any way to squeese the 8" thick one in without cutting it.
Karalyn
Old 01-22-2007, 06:10 AM   #5
We put the Walmart 8" mattress in and didn't cut it. The corners are compressed and you can't tell the mattress wasn't custom cut.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 01-22-2007, 07:06 AM   #6
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
A quick web search shows that a full size bed is typically 53-54" wide by 75" long. The earlier thread reported that their 16' was about 45" wide and the owner of the 17' said his was near full size which I presume means close to 53" wide. I don't think a full size mattress will fit a 16' but toppers that can be cut are a possibility.
Also,
Old 01-22-2007, 08:01 AM   #7
Jeanne and Steve's Avatar
Trailer: Casita 16 ft 1984 and U-Haul CT13 1985
Karalyn,
I tried squeezing our 6" full-sized foam/memory foam mattress from Walmart into our 16' Casita but it was much too tight a fit. It's interesting that Charlie was able to put a full-size mattress into his SD without cutting it... maybe the bed area is wider in the newer Casitas. Have you measured your bed to see what its dimensions are? Ours was 45" X 75". I ended up cutting the mattress to size with an electric knife, but I think 6" is about the maximum thickness my knife would have been able to cut. (An upholstery shop could cut it for you if you discover it's too big for your electric knife, however, even the 6" mattress was very heavy and difficult to move around... the 8" one would be even more so!)
The mattress cover was removable, so it was easy to re-stitch it to the new size. We love our new mattress!
Jeanne
Jeanne and Steve is offline   Reply With Quote
Old 01-22-2007, 09:11 AM   #8
Trailer: 2002 17 ft Casita Spirit Deluxe
If you have a factory propane heater and the air intake is on the bed side, please take caution to not block the opening with the addition of a mattress topper. Memory foam is fairly heavy and I imagine one that is 8 inches thick will weigh quite a lot. Just a suggestion here - what we did was add a 2 inch layer of egg crate foam from Walmart, and on top of that a 2 inch layer of memory foam. The 4 inch addition on top of the cushions sleeps very comfortably and does not block the flow of air to the heater. I suppose, if one were to remove all the cushions and then use an 8 inch mattress, would be ok, but, I do have reservations about the weight with a thick memory foam. Don
Donald Stahl is offline   Reply With Quote
Old 01-23-2007, 08:23 PM   #9
Karalyn's Avatar
Looks like Charlie has the 17' model and a bigger bed.
wondering about that propane intake??
I don't think there is one in the 16' model, is there??????????
Karalyn
Old 01-23-2007, 08:35 PM   #10
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
Casita 17' SD is 54" wide
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
casita
non opening rear window 13 ft Casita PD Diane H Problem Solving | Owners Helping Owners 9 08-08-2015 09:23 AM
Hitch Added To Rear of Casita Patrick M. Towing, Hitching, Axles and Running Gear 16 06-21-2011 08:46 AM
Wanted: Casita rear overhead cabinets DayTripper Classified Archives 1 09-26-2009 06:51 AM
1989 Casita Question CathleenC Modifications, Alterations and Updates 1 06-25-2009 07:33 AM
Help with a 13' Casita sagging in the rear Cliff in SAV Problem Solving | Owners Helping Owners 3 07-15-2006 11:39 PM
