Casita vs Bigfoot MPG - Page 2 - Fiberglass RV
Old 03-23-2013, 12:07 PM   #15
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by David and Nancy View Post
I have had a Scamp 16, Casita 17, 2 Bigfoot 21's and now a Bigfoot 25. I towed them all with a Ford F-150 with 5.4 liter engine. Mileage was identical between the Scamp and heavier Casita. I lost between 4-5 miles per gallon when going from the Casita to the Bigfoot 21. But when I went to the Bigfoot 25, there was no further change. The 25 and 21 have identical frontal configurations. This must be a greater factor than weight. As for the 4-season capability, only you can decide if you need it. I know I love it where I live. I can be in elk camp in single digits in November and still make full use of the plumbing.
If this isn't a perfect demonstration that trailer front surface area is the most critical factor, I don't know what is.
Bookmarking this page for future reference...thanks, David!
Francesca
Old 03-25-2013, 08:02 AM   #16
David and Nancy's Avatar
Trailer: Bigfoot 25 ft (25B25RQ)
You are welcome, Francesca. We love our Bigfoot, but aerodynamic it is not. Too many flat surfaces. I can feel the wind grabbing it. Egg-shaped trailers just fly better. Bigfoots are basically square with slightly rounded corners.
David and Nancy is offline   Reply With Quote
Old 03-25-2013, 11:45 AM   #17
Manitoba
On your 4th rainy day, when you can stand with your arms outstretched and twirl without hitting anything; when you are admiring the view out of all those large windows; its just worth the mileage.
Old 03-25-2013, 09:26 PM   #18
Trailer: 2017 Escape 19
I second what David and Nancy and Cam A say! It may not be the sleekest egg out there, but oh, those windows and oh, all that room! For us, that's worth the slight loss in MPG.
Evergreengirl is offline   Reply With Quote
Old 03-25-2013, 10:37 PM   #19
The Bigfoot's plenty sleek- not that much "squarer" than many of our rigs. It just has more frontal surface area than most fiberglass trailers, which is likely what causes the extra drag.
And I totally agree with those that appreciate the extra area- A space that two people can actually stand side by side in sounds like heaven to me!
Francesca
Old 03-25-2013, 10:57 PM   #20
deryk's Avatar
New Jersey
we all have to decide what we want in a trailer (sometimes its why people have more then 1) If your worried about the cost in fuel then get the casita, if your not concerned about lesser gas mileage then buy the bigfoot. I like that Im getting a little better gas mileage then my vardo so Im happy...but Im also single. If I was traipsing around with a few others I would want a little more room so I could have some privacy lol.
deryk
Old 03-26-2013, 12:10 AM   #21
LeonardS's Avatar
Trailer: not yet
I've been looking at Escape 15's and Trillium 4500's. Both look a little boxy compared to Eggcampers and Casitas and Scamps. But...are they really boxy enough to effect mpg like the Bigfoot?
LeonardS is offline   Reply With Quote
Old 03-26-2013, 03:16 AM   #22
GPJ
Trailer: Looking
You really don't need that much rounding to obtain a real aerodynamic advantage - some of the aerodynamic studies I have looked at indicate that rounding (front sides and top) with a radius of 6-8 inches gives much of the available aerodynamic benefit. Beyond that there is a rapidly diminishing return. As has been pointed out above, if all else is equal, frontal area is a big factor in total drag. If your trailer is taller and wider - you get lots of room inside, but pay the piper at the gas pump.
In your example, I'd say the Escape 15 and the Trillium 4500 would have mpgs very similar to the Scamps and Casitas due to aerodynamics, frontal area and also weight. The Bigfoots really are another class of trailer - bigger inside with heavier double wall construction. Remember, Nancy and David's Bigfoot is a 25' model according to their info - you can't really compare it to a 15' egg.
GPJ is offline   Reply With Quote
Old 03-26-2013, 11:46 AM   #23
Front surface area is the main difference between Bigfoot and the other brands you mention, especially since without exception all fiberglass trailer backsides are equally wrong for efficient aerodynamics.
Per comparison of Trillium with Escape:
The Escape 15 and the Trillium 4500 shells have a common progenitor and one of the things they share are identical frontal profiles/areas.
Francesca
Old 03-26-2013, 07:35 PM   #24
Brian B-P's Avatar
I agree that the frontal area is a - or the - big issue, but there is a substantial difference in front corner rounding, and...
Old 03-26-2013, 07:38 PM   #25
Brian B-P's Avatar
I agree that the typical egg is all wrong in the back, but again the current Bigfoot shape is more squared, which is actually the better design for the back end.
I agree. As for the rest...
Sure. In rough order of most round (egg shaped) to most square:
  1. Oxygen
  2. Boler(1300/1500/1700)/Scamp/Casita
  3. U-Haul/Burro
  4. Trillium/Surfside/Escape
  5. Compact, Bigfoot, Biggar, Boler 1650/etc
... and of course I have left many out. Within the models of a brand (and of the same approximate vintage, for those few that have actually evolved their shape with time), they are usually all similarly shaped.
The Snoozy doesn't fit in this list, because it has a rounded front (even though not a great approach to rounding for aerodynamics) and relatively sharply cut off back, as I believe they all should. It is annoying to me that essentially all of the designers - other than the Smoaks - shape the front and back similarly, almost as if there is no regard to which way the trailer is going. Just a pet peeve...
Old 03-26-2013, 07:40 PM   #26
I'm waiting for somebody to tow the Lil' Snoozy backwards for a 1,000 miles and compare fuel consumption with towing it forwards. Then we will have the definitive answer.
Old 03-26-2013, 09:45 PM   #27
LeonardS's Avatar
Trailer: not yet
Now THAT made me laugh out loud!
Old 03-27-2013, 07:59 AM   #28
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Interesting article on motorcycle aerodynamics including discussion of Kamm tail (squared off back). Tony Foale Designs, article on motorcycle aerodynamics.
This discussion of the effect of side winds is interesting, too.
bigfoot, casita
How many MPG Kevin K General Chat 56 11-27-2013 12:48 PM
MPG Adrian W Towing, Hitching, Axles and Running Gear 17 08-28-2009 09:06 AM
MPG Phill Roehrs Towing, Hitching, Axles and Running Gear 27 03-17-2009 06:45 PM
MPG Adrian W General Chat 0 12-31-1969 07:00 PM
